Question about Maytag MDB6658 Built-in Dishwasher
Flashing lights My dishwasher will not work. All the lights are flashing. Is there something that can be done to reset the dishwasher?
  • 248 Answers
Try unplugging for a minute. If this don't work it may need a board.
Posted on Oct 08, 2007
SOURCE:
Normal + rinse light flashing on dishwasher
it sounds like something has came loose. you have to take the control panel apart and you should find a grey flat plastic cabel about 2 1/2 to 3 inches wide.hook it back up and maybe use some electrical tape to keep it in place and that should fix it.
Apr 15, 2014 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Maytag MDB6658 Built-in Dishwasher Logo
169 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
