Question about Solid Audio Formula Series F27 2-Channel Amplifier Car Audio Amplifier
F-27 in Bridged mode at 2-Ohms/Url of Solid Audio
I want to ask that may I use Solid Audio F-27 2-Channel Amp in Bridged mode (single channel mono)at 2-Ohms for attaching my DVC pioneer Sub? Is this Amp stable at 2-Ohms or not? Secondly I want to ask the web addres (url) of Soild Audio as the does not work.
4 Suggested Answers
  • 98 Answers
SOURCE: solid audio f29 2 channel
With the no name amps theres not alot you can do. Even with the high end amp companies you cant get much info and parts out of them.. If you happen to be in the chicago area i do run a small repair shop and i would be happy to take a look at it and see if theres any way to repair it....
Posted on Aug 18, 2007
  • 26 Answers
Posted on Jun 07, 2009
  • 32 Answers
SOURCE: how many speakers and woofer solid audio f2000 2
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Posted on Jul 12, 2009
    • 1126 Answers
    SOURCE: 2 12" dvc subs 2 ohm stable amp
    + on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
    Posted on Nov 12, 2009
    0 characters
    1 Points
    When amp is bridged and I turn it up it starts to cut the speakers off, still has power to amp but want start pushing the speakers until cut down, what is my problem?
    Ohm's Law for Alternating Current states that I = V/Z where I is current, V is voltage, and Z is impedance. We also know that P = IV, where P is power. If we use Ohm's Law and substitute into the power equation, we get P = V(V/Z), which can be rewritten as P = (V^2)/Z. Therefore, power is the square of voltage divided by impedance.
    Now, why do we care about all that? Because it explains precisely what happens when an amp is bridged. I'll give a practical example and explain the theoretical basis of that example.
    Imagine you have a two-channel amp that puts out 50 watts into each channel when driven into a load of 4 ohms per channel. Since we know P and Z, we can plug these numbers back into our power equation and find V. 50 = V^2/4 -> V = sqrt(200). So, we're seeing a voltage of 14.1 volts across each channel.
    Now, imagine we bridge this amp, and use it to push just one of those 4 ohms loads. When the amp is bridged, the voltage is doubled. Since we know the voltage (2*14.1 volts), and the impedance (4 ohms), we can calculate power. Remember that P = V*V/Z. That means P = (28.2)^2/4, which is 198.1 watts. It should be clear by now that the new power is approximately 200 watts - quadruple the power of a single, unbridged channel!
    You can probably see that should be the case, especially if you look back at the power equation. Since P = V*V/Z, if you double V, you quadruple power, since V is squared in the power equation.
    Now, all this assumes the amp is stable into 4 ohms mono. The mono channel is putting out four times as much power as a single unbridged channel, so it must be putting out twice as much as the two single channels combined. Since the voltage on the supply side of the amp is dependent on the car's electrical system, it doesn't change (OK, the increased current might cause a voltage *drop*, but let's not worry about that now). Looking at the first power equation, at the supply side of the amp, we see P = IV. Now, when we bridged the amp, we doubled the power, but the input voltage stayed the same. So, if we hold V constant, the only way to double the power is to double the current.
    That means the amp is now drawing twice as much current when it's running at a given impedance mono than it would be running two stereo channels at the same impedance. There are only two ways the amp can do that - it can simply draw more through it's circuits, and dissipate the extra heat, or it can utilize a current limiter, to prevent the increase in current. Of course, using the current limiter means you don't get the power gains, either! So, if the amp can't handle the extra current, and it doesn't limit the current in some way, kiss it goodbye. For that reason, an amp is typically considered mono stable into twice the impedance it is considered stereo stable.
    Mar 20, 2015 | Car Amplifiers
    Wiring a crossfire vr602 at 4ohm
    OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
    Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
    Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
    Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on Thanks!
    Dec 18, 2009 | Car Amplifiers
    Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
    165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
    Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    It has an A and B channel for spkrs and i have one spkr bridged. do i split the neg to side a and pos to side b or just use one of the channels?
    Could you elaborate on how the speaker is bridged?
    I think you want to hook up a single speaker to a stereo speaker output.
    In this case, you would strap (bridge?) the right and left speaker terminals by running a short wire from A right negative to A left negative. Then strap A right positive to A left positive -- this will give you mono output on either of the right or left speaker terminals -- connect your speaker to either one of these.
    Do you know what the ohm rating is for the speaker outs on the amp and also the speaker itself?
    Aug 31, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
    2 ohm speakers wont work on a lanzar max pro 4000 watt
    The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
    Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
    Two terminals? bridging theory?
    Hello again jm129852,
    Having two power and ground terminals allows you to run two smaller wires instead of one big one. It's a convenience. No, you do not have to use them both. They are connected together inside. Yes, you should still use a single fused battery lead. Connect the big wire and fuse holder to the battery and to a distribution block and run the smaller wires from the output side of the distribution block.
    When you connect the outputs of a two channel amp to two separate speakers, each speaker gets the power produced by it's channel only. If you are using only one speaker, and the amp is rated to operate bridged, then the speaker will receive the power from both channels, typically twice as much. You do need to be careful when using bridged mode because many amps will only operate safely at a higher impedance when bridged. For example, when operated with both channels connected to separate speakers (not bridged), it may be stable to 2 ohms. But when you connect both channels together (bridged), it is only stable to 4 ohms. Usually, the specifications will tell you the lowest impedance at which the amp should be operated. The specifications for the current RF Punch 500.2 are like this: 125 watts X 2 at 4 ohms; 250 watts X 2 at 2 ohms; 500 watts X 1 bridged at 4 ohms (4 ohm stable in bridged mode). You would NOT want to connect two 4 ohm subs in parallel to this amp in bridged mode. It would result in a final 2 ohm load and the amp would overheat and fail. One 4 ohm sub would be OK, and it would receive the full 500 watts as stated in the specifications. You could connect four 4 ohm subs, two each in parallel to each channel, and the 2 ohm loads on each channel would be OK. Or you could series two of them together for an 8 ohm load, do the same with the other two, and then parallel the two 8 ohm loads for a final impedance of 4 ohms and connect them into the bridged terminals. With DVC subs the connection possibilities get more complex. There are many good impedance calculators online that can help you determine the best wiring solution for various amp/sub combinations. I like the one above at web site. Rockford-Fosgate also has one which allow you to select the a number of subs (up to 4), their voice coil configuration (single or dual), and the voice coil impedance. The RF calculator then shows you what configurations are available and what your final load impedance will be.
    Hope this helps.
    Apr 28, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
    Amplifier loads
    Hello ronnieyannon,
    A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
    I'd wire them the way you have them wired.
    Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
    Hope this helps.
    Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Ccan it be bridged with a 5 ohm subwoofer?
    Hello cameron_cran,
    The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
    Hope this helps.
    Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
    How to get the best out of this amp
    "google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
    Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
    Solid Audio Formula Series F27 2-Channel Amplifier Car Audio Amplifier Logo
    138 people viewed this question
    Top Solid Audio Car Amplifiers Experts
    Tygh Duval
    Tygh Duval
    Pablo Gonzalez
    Are you a Solid Audio Car Amplifier Expert? Answer questions, earn points and help others
