Question about Refrigerators
The evaporator ices up enough to get ice to the circulating fan. as the ice begins to touch the fan it begins to make a lot of noise. then when the ice stops the fan no more cooling. the drain is also freezing. i have replaced the circulating fan once and have to watch it very close so that it doesn't burn out again. how do i test the continuity on the defroster element and if that isn't the problem what is the next step? This is a bottom freezer unit.
  • 3 more comments
  • ergbtn1 Apr 23, 2009
    I have removed the bottom tray of the refrigerator section which exposes the coils, fan, drain line leading from the evaporator area and using a hair drier I have defrosted the unit. All works well for a few days or maybe even a week and then the problem starts over.
    note of interest; this unit is installed in my garage. The installation is near Houston Texas. Very humid during the summer. Season of the year seems to have no bearing on occurences. How do I test the defroster heating element? With the bottom tray of the refrigerator section is very obvious. Should this be disconnected on both ends and then checked for continuity? What if continuity is ok?
    Refrigerator Brand GE
    Model number GBS18HBRAWW
    Serial number FG903440V
    I have checked the defrost element and it is ok. How do I check the defrost thermostat? Is there a wiring diagram available on the internet?
    Ron G.
  • ergbtn1 Apr 24, 2009
    Ben,
    I poured a cup of warm water down the drain and it drained perfectly. The last tech said something about a defrost thermostat. How do I check this out? Is the small round cylinder that is attached to the metal pan under the coils a freeze switch?
    Tnx
    R G
    I did not get an answer about my last reply. The comment was that I poured a cup of warm water down the drain and it was open all the way to the drain pan. The last question was how do I check the defrost thermostat and what is the small round cylinder attached to the tray under the coils, is that a freeze switch?
    I only got one e-mail informing me of a suggestion. Luckily I didn't delete the e-mail and had it to get to the web site on every occasion.
    Thanks
    R G
  • 15,935 Answers
CLICK HERE for expanded blowout views of your fridge.
You could be talking about the Dryer (part 123 on the UNIT PARTS diagram)
Or the thermostat #10 on the CABINET diagram.
These are both near coils. One evap. coil, the other condernser coils.
Directions for testing a refrigerator defrost thermostat.
Before you begin to test your defrost thermostat, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
  1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
  4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
  5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Use the "Continue with this expert" feature if you cannot locate your part.
(or you could take a picture and post it)
Without actually seeing it - it is hard to guess about what you are seeing.
If you find your part - Parts Select is a very trustworthy (and priced right) site to order from.
Let me know!!
Thanks!
Posted on Apr 24, 2009
  • 3,037 Answers
It sounds like your drain hole may be clogged and so the moisture is having trouble getting out. It may be clogged with ice and your hair dryer doesn't get it because you don't aim for it and only got the coils which in fact were not the problem. I would leave the unit unplugged overnight to totally defrost it and I would try seeing it anything is clogged up the drain by running a tube or something up it to free it up if needed.
Benjamin
  • Refrigerators Master
  • 19,396 Answers
The evaporator must not ice up in this way. If it does, then it is not working fine.
To test the element continuity put a multimeter on ohms (impedance) and check if the element have infinite impedance, if it does, there is no continuity and element is broken.
If element is fine, then check the defrost thermostat.
Posted on Apr 23, 2009
  • 527 Answers
Plz provide brand name and model no.
thanks
  • Asfiya Ahamed
    Asfiya Ahamed Apr 23, 2009
    Remove the rear panel inside the freezer section and you will see silver evaproator coils.  Underneath these coils is a drain pan.  Using a hair dryer, defrost all the ice and then unblock the drain line.  Reassembly and all should be fine.
    Sergeant:
  • 199 Answers
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our side by side has a lot of condensation in it and it is leaking out the door. any ideas. Just the refrigerator side.
The moisture in the fridge gets circulated to the freezer where it is removed by the evaporator. If the fan in the freezer is not running it can't circulate the air. Also if the vents to the fridge are blocked the air can't circulate. There is one at the top and one at the bottom.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 03, 2010 | LG Refrigerators
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
Fan begins to make noise - then fridge stops.
You have a defrost system failure and needs to be checked.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hairdryer to warm the back wall, 20-30 min, put everything back, turn it back on and you should be good for a couple of days.
Dec 17, 2008 | LG (LRBC22522ST) Stainless Steel
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Refrigerator Buzzing
if my guess is correct, that buzzing sound could be coming from the evaporator fan touching the ice that builds up in the evaporator. if that is true, a quick remedy for the noise to disappear is to thaw the ice, unplugged it for a while but as ice builds up again, then the noise would come back. the original problem would be the defrost cycle not functioning well. will be in touch if my guess is correct. thanxs,
Feb 11, 2008 | Refrigerators
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
