Question about Acer Aspire 5500 5570-2609 Laptop
I CANNOT OPEN!!!
Anyone who could help me for my problem..I have an Acer aspire5570, i dont know what the problem is, when i turn the laptop on it doesnt work.. no light indicator..as in no power light..i tried to take the battery, and put it back again but it doesn't work..pls help me..
  • junloto May 18, 2008
    I have the same problem with my acer 5570 laptop. It wouldn't power on.
Same problem here just happen, tried all these things nothing. sent tech support e mail nothing back yet. anyone find out let us know. guess i have to buy anothor laptop sure won't be acer got this one on june 07.
Posted on May 24, 2008
  • gary gray May 24, 2008
    Read this one also
    POWER JACK REPAIR .ORG
    Power Repair service techs could be reach at (847) 529 9441 seven days a week.
    Blinking green light on the laptop AC adapter
    If your laptop ac adapter also known as a power supply has a blinking or flashing green light and the laptop / notebook system does not power up at all while the ac adapter is plugged into the laptop, then you have a short on the motherboard.
    What are the symptoms of the short on the laptop motherboard?
    You plug in your ac adapter into the wall ac power outlet; the light on the ac adapter is solid green at that time. As soon as you connect the ac adapter’s plug into the laptop the light on the ac adapter dims and does not show green at all until the next time you unplug the ac adapter from the laptop and from the wall or the ac adapter could simply be blinking green. At the same time system does not power up from the ac adapter.
    What this means?
    This means that once the short is being encountered the AC adapter, power brick, power supply shuts itself down, once it shuts itself down the green light goes out. If the ac adapter is more advance it tries to restart itself thus the blinking light. Every time ac adapter restarts the shortage happens and thus the light comes up and dims out.
    Is it fixable?
    No, if you do it yourself. There isn’t a device out there that could show you where the short is at on the motherboard.
    Can we fix it?
    Maybe. The chances for dell computers that have a blinking light are about 60% that we can fix it because we know what to look for, again there are no tools out there that can identify where the short is at but since we are in business of power repairs on laptop computers we for the most part know where to look for the short. Again chances for dell computers are 60%. For all other computers are about 40% chance that we will find where the short is at. Again we can only fix it if the light goes out on the ac adapter, or keeps blinking green whenever you plug in the ac adapter into the laptop. Keep in mind we are one of very few companies, maybe the only one in U.S. that can actually fix that shortage issue.
    How much would it cost to fix it?
    There is no diagnostic or any other fees. We only charge you if the system is working fine after the repair. The price structure is as follows.
    If you send the whole laptop to us with the ac adapter we will need 2 checks from you, first check for $10 to cover the return shipping back to you the second check is for $115 for labor. If we fix the laptop and it works fine we keep both checks $10+$115 = $125. If we won’t fix the laptop and it does not work fine then we only keep the $10 check to cover our return shipping cost. Or just make sure to include prepaid return label and don't worry about the $10 check for return shipping.
    Turnaround times?
    We keep the system here no more than 24 hours.
    Where to send the laptop to?
    1) Make checks out to Applicasoft. One for $10 another one for $115
    2) Make a note specifically stating that you have a short on the motherboard
    3) Make a note saying where to ship the laptop back to, as well as your phone number and email address if you want us to send the tracking number to your email address.
    Send WELL PACKAGED laptop with the AC adapter to:
    Applicasoft
    710 MILL CIRCLE #107
    WHEELING, IL 60090
    (847) 529 9441
    blinking@powerjackrepair.org
    If you are in Chicago land area feel free to stop by but please call to make an appointment.
    Most common systems?
    Dell M500 M600 M700
    Dell Inspiron and Latitude
    Other computers such as sony, acer, Toshiba, hp, Compaq, averatec, also have the same issues but they are much harder to work with, but it is the same price.
    _uacct = "UA-1472122-1";
    urchinTracker();
    var sc_project=706955;
    var sc_partition=5;
    var sc_security="be535f56";
    var sc_invisible=1;
    urchinTracker();
    var sc_partition=5;
    var sc_invisible=1;
    Brigadier General:
  • 6,966 Answers
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 24, 2007
I left charging my acer aspire 3560 last night. The next day i found the cable underneath the laptop the whole time it was charged so i disconnected the charger away from the laptop to unbend it and used the laptop until it died. So the next thing I do is connect the charger to charge my laptop and nothing happens!! It does not charge there no battery light indicator , it turned on for about 2 min and on icon battery it did not show the charger plugged in but it was plugged in. After that it died entirely and does not charge or nothing. I already plugged in a lamp on the outlet I used to plug in the laptop but the power outlet does work so I don't know it it's the charger that doesn't work or what could it be. Please help i really need my computer I'm afraid that it won't turn on again. I would appreciate if someone could help .. thanks
Posted on Sep 25, 2009
Does the acer aspire 5570Z-2758 have a built-in microphone, and if it does, where is it and how do I turn it on?
As per the specs on this site:
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5570/Aspire5570sp2.shtml
It does have a microphone.
You should be able to turn it on by going into your sound options :
Down in the lower right-hand corner you should see your volume control icon. Double click on that and it will bring up your volume control panel. Your microphone control should be listed here. Just make sure to uncheck the mute box and turn it up.
You may have to go to "options" and check "microphone" to get it to show up.
You may also need to go into the sound options (Start->Control Panel->Sounds and Audio Devices) to enable the correct recording device. Once you're in this window select the Audio tab and make sure your microphone is selected as the default recording device.
That should do it.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 21, 2011 | Acer Aspire 5570-2758 Notebook
Aspire 5570 need driver for windos 7
Dear thoys15,
Acer haven't yet officially released windows7 drivers for Aspire5570. But you can use vista drivers for your windows7 operating system.it is compactable .
please download vista drivers for your Aspire 5570 from this link.
http://support.acer-euro.com/drivers/notebook/as_5570.html
Thanks for your Posting
Jun 22, 2011 | Acer Computers & Internet
I cannothave acer driver cd for acer aspire5570
You can download the drivers from the Acer WEB site. Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require and it matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/notebook/index.html
Jul 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Has the acer aspire 5332 got a webcam?
You can ask the company if you can have one installed because I don't think they come with one. You can always buy a 20$ webcam on the side. Or pay the 80$ to have a webcam built into the laptop. Your choice.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
I cannot access my webcam as i installed windows vista in my aspire5570.....can u help me with that????
hi
follow this link to the acer website an select the webcam you are using and begin your driver download that will update the driver you currently have installed (if any)
Jan 25, 2010 | Acer Aspire 5100 Notebook
Bios password
The only way to solve your BIOS password is to open the laptop and remove its button cell meant to run the clock and BIOS. You will have to reach the mother board and do it. Remove it for a minute or so and then connect up everythig as it was. And remember not to gove any passwords any where in future.
Aug 21, 2009 | Computers & Internet
I dont know how to open a acer aspire 3690
please follow pictures you may open your laptop:
1) open some small cover at back of laptop
2) take away cpu fan and sink careful fan cable.
3) open the cover and keyboard on the laptop careful KBcable.
4) take away LCD unit and a big cover on the motherboard caeful the mousepad cable.
c8bc221.jpg hope help you fix it, please rating me and keep in touch for any question thanks
May 14, 2009 | Packard Bell Easy One Silver 2120 Notebook
Cursor locks up on my acer extensa 5620
you need to go to your control panel then power options, on the power schemes turn the 3 setting you have to never.
let me know how you get on
Feb 16, 2009 | Acer Aspire 9300 Notebook
Ether controller acer aspire5570
Go to the Acer support site
http://support.acer-euro.com/drivers/downloads.html
and find them
Dec 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
Ethernet controller
plz check the manufacture website for drivers
Jul 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
492 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
