It is struced
Dear Sir, Actually my ipod has structed.When i connect to cpu it is not detecting .And I don't know how to swithoff this.
Hi how do u? sir i want to get some information about ipod mp3 4gb .sir its problem i cant understood its prblem like thiz my ipod is not detected from the computer i want to copy music form computer to...
Does your ipod turn on?
Try resetting it.
After unlocking the device, hold the middle and Menu button together until the device reset. You should see the Apple logo. Let it go and then it should start. Try connecting it to Itunes.
Mar 13, 2011 | Apple iPod nano
I have iPod classic i think My iPod is hung.It shows me Cable symbol and Ok to Disconnect Message.I can't do any thing i mean Pressing Menu/center button i have not got any response from iPod.Please help...
Hello Sir,
Connect your ipod to itunes and do the following,
1.)Open itunes
2.)Wait for the itunes to detect your ipod.(Be sure your connected to internet.
3.)As the ipod gets detected itunes may show the ipod to get restored. Then try restoring your ipod.
4.)Or just click the ipod on the left pane in itunes.
5.)Then choose restore connecting to internet. Thats it your ipod will be reversed to its factory setting incase of any corruption or virus. And starts working normally.
Thank You
Aug 09, 2010 | Computers & Internet
File NTLDR missing
If NTLDR file is missing may be of OS corrupted. Place the OS CD and try to recover the file. if not re-install the OS and do not swithoff the CPU without proper shutdown.
Let me know that i had fixya! the problem
Apr 15, 2010 | Acer Aspireā„¢ T180 PC Desktop
ITunes screen freezes on connecting the iPod. The ipod is not detected by iTunes even in disk mode. No menu of iTunes opens up when iPod is connected
if itunes is freezing when connecting the ipod then 1 of 2 things are happening
the ipod has an error on the disk and needs to be replaced or your anti- virus is going to scan your ipod for virus and can because its an ipod -
so test your ipod with another cpu that will tell you alot
if it freezes itunes on 2 different cpu then its the ipod -if it works fine then its your anti-virus - you need to disable or remove
norton is Nestorius for this
Jan 23, 2010 | Apple iPod nano
Apple ipod mp3 player unable to detect
if you ipod is not being seen by itunes but shows in my cpu then ipod try these steps in order
http://support.apple.com/kb/HT1363
then
http://support.apple.com/kb/ts1363
if these steps do not work try another cpu to see if it shows on any cpu
if it dose not show on any cpu then it might be a problem with the ipod
then go to apple store or call apple care
Oct 10, 2009 | Apple iPod MA446LL/A MP3 Player
Sir' my ipode nano 8gb's screen and sound section
Connect i8t to system and when detected as a removable device,goto ipod_control>device and delete _locked...its a hidden file
Sep 08, 2009 | Apple iPod nano
Transcend t sonic 850
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "volume -" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Sep 02, 2009 | Transcend T.sonic 850 Digital Media Player
"do not disconnect" + plus flashing red circle w/ bar through it. How do i resolve this problem? Does not happen when the ipod is not connected to the cpu.
You might need to clarify what you mean. When ever a ipod receives a signal that it is connected to a USB it will display the "Don Not Disconnect." This could happen even if it is not connected if there was a disruptance and was sent this message by mistake. You say it does not happen when iPod is not connect to CPU, what CPU? You connect through a USB, not directly to a CPU. Either way, a soft reset, (push Menu and Select of the Middle button at the same time and hold for about five seconds) may take care of this. Even if it was connected properly it would still reset the iPod. This is the best tool for any problem. If that doesn't work, you'll need to clarify what you meant. It sounds like you say it has the do not disconnect sign except when its not connected which is what is supposed to happen.
Aug 29, 2008 | Apple iPod MA446LL/A MP3 Player
System reporting erros message
blue screen before the OS to load or after the OS to load
Well if after the OS to load try formatting your hard drive it might solve the problem
Jul 04, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
