Question about Dell W2606C 26 in. HD-Ready LCD Television
Truns off by self
My tv turns off by itself after every 10 minutes
  • Dell Master
  • 3,866 Answers
Check sleep timers make sure you have non set in the menu or setup if not the timer inside is gone south on you and will need repair.
Posted on Apr 23, 2009
What happens when you trun on the tv and its cut off
Many circuits today have safty features.
If it's turning itself right back off even with the manual on button it may be a self protection against a short. Don't force it and check the outlet you have it plugged into for ground faults.
Feb 06, 2015 | Televison & Video
Why does my tv trun off by itself?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 13, 2014 | Proscan Televison & Video
Truns off by it self
If tv turns off and back on by itself then its problem of lamp that is dying and near to end of its working life span.
Replace lamp in tv to fix the issue, lamp replacement procedure would be written in user manual and its easy.
Let me know if you have additional question.
Jul 31, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
2002 Chev Siverado,2500hd duamax dielsel. Changed the two batteries becuase the others died. Now I cannot start the engine. The engine truns over good. The security light flashes.
It sounds like the anti theft pass key's have most it's memory and needs to be reset. Try this, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help
Jun 30, 2009 | 2002 Chevrolet Silverado 2500HD
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Dell W2606C 26 in. HD-Ready LCD Television Logo
220 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
