Question about Refrigerators
What type of refrigerant does the system use?
What type of refrigerant does the 2003 ford expedition use
  • Rodney Wilkinson Nov 16, 2011
    is this the kind that will use the hose and attachment that you use on car's systems?
  • 358 Answers
They use 134A.You can buy it in any autoparts store .It comes in a 12oz can.
Posted on Apr 23, 2009
Passenger side on 2003 ford expedition keep dropping no air leaks
On that system you have 3 ride height sensors. 2 front 1 rear. Disconnect the linkage arm and try to move sensor arm. Should move with little resistance but not loose. If bound up replace,also check 2 remaining sensors. Behind the passenger headlight is your compressor and relay. You can jump the 2 fat wires together at the relay to activate the compressor. The relay has 4 wires 2 fat 2 skinny. They sell a conversion kit to elinmate air ride and have coil struts and shocks. I normally recommend the conversion so the problem doesn't happen again. Nice system till it goes wrong
Mar 14, 2015 | 2003 Ford Expedition
Check engine light on 2003 ford expedition
Can't help you
Those type check lights, have been on all
vehicles since 1983, some 30 years
You know the drill
Check for Codes
Diagnose using the code & trouble charts
Resolve or Repair
Jun 08, 2012 | 2003 Ford Expedition
I have a 2003 ford expedition xlt and the a/c is not working. It has a new compressor plus the blowers changed. If I accelerate with the mode on max it goes off, but let up off the gas and it blows...
By 2003 most air-con systems had considerable electronic control and your problem might be caused by a malfunction there, wiring problems, compressor clutch problems or maybe there is a leak and the refrigerant pressure has already fallen to the point where the system is ceasing to work depending on temperature.
Dec 10, 2017 | 2003 Ford Expedition
Which firing order goes out first on a 2003 Ford expedition?
For 2003 Ford Expedition there are 4 different engines:
For Expedition 4.6L engines: Firing Order 1-3-7-2-6-5-4-8
For Frod Expedition 5.4L engines:
Firing order 1-3-7-2-6-5-4-8
Ford Expedition 4.0L engines:
Firing order 1-4-2-5-3-6 ---
For Ford Expedition 6.8L engines:
Firing Order: 1-6-5-10-2-7-3-8-4-9
Jul 29, 2011 | 2003 Ford Expedition
2003 Ford Expedition - What do blinking red lights signify?
Do you have an alarm system installed? These sound like the alarm indicator lights. They are supposed to deter theft and break ins.
Jul 24, 2010 | 2003 Ford Expedition
Ford 2003 Expedition EB. Check Charging System
Its probably the alternator. It will need to be tested on the vehicle with the engine running and the light illuminated. Measure the battery voltage with the engine running. It should be at least 13.5 volts. If it is lower have the alternator tested at a shop with a charging system tester.
Feb 27, 2010 | 2003 Ford Expedition
2003 Ford Expedition AC not working
If the system does not have a major leak it could just be normal leak down through the hoses. If it is still pressurized you should be able to get a can of refrigerant (R134A) and a hose to put it in with from your local parts house or even Walmart. Unless you can see oil seeping out from hose connections or fittings it is reasonable to assume the system is not damaged.
Jan 17, 2010 | 2003 Ford Expedition
Ford Expedition Battery and system charge warning
If he replaced the battery that would have cleared the code. There is another issue. Was the alternator aftermarket? Just becuase it is new does not mean good. Those are easy to install I would return it to where you got it and try another.
Oct 08, 2008 | 2003 Ford Expedition
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
