Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Central Pneumatic 94667r 3 hp electric oiled compressor
Will only build to 20 pounds of pressure and refuses to go any further. It builds to 20 pounds quickly but no further. I let it run for over 20 minutes and it never went past 20 pounds. This is the first time I have tried to use this unit as I just purchased it 'as-is' the other day. I followed all the instructions in the manual. I did notice that the sound of the compressor is slightly different once it reaches 20 pounds. It reminds me of a pop-off valve coming into play some way, but I have no basis for this other than a gut feeling. One other odd thing is that there is quite a bit of air flowing out the oil fill cap when it is running. Maybe a back-pressure leak ?? Thanks for any guidance.
  • 116 Answers
Sounds like your check or reed valve is bad. when the piston pressurizes and pushes air into tank the pressure should not be able to come back into cylinder and thsi is what its doing and then that pressure is now going past rings into oil. look for the valve before the tank. a check valve.
Posted on Apr 23, 2009
  • just2tall65 Jan 05, 2011
    i have the same problem as daniel9913. my central pneumatic compressor keeps running but builds no more pressure once it reaches about 22 psi. where is this check or reed valve located?
The diaphragm at the bottom of the black power switch box has a split in it. Remove the top of the black power switch box by removing the single philips head screw accessible through the hole next to the red switch knob. The switch/diaphragm can be removed by taking off the 4 bolts at the base of the switch. Using model # call Harbor Freight for a suitable replacement switch and gasket. I haven't been able to find the gasket by itself.
Posted on Nov 03, 2011
Central pneumatic 61693 problems
Without seeing and being able to do hands-on trouble-shooting I can only make a shot-in-the dark analysis.
I, years ago had a similar situation, and it turned out that my compressor was one which REQUIRED LUBRICATING OIL IN THE CRANKCASE [just like a 4-cycle lawnmower engine].
I had failed to regularly check the oil level and over 4 or 5 years it had "used up" the oil and was beginning to run dry. Dry bearings build additional friction which will cause "drag" and slow the compressor RPM!!!!! That could explain the inability of your compressor to exceed 20 to 30 Psi!
With enough dry running, the bearings within the compressor will eventually totally wear out, and FREEZE-UP, locking the compressor up. Once that happens, the compressor will have to be replaced, OR OVERHAULED, just like you would do with a frozen bearing in a lawnmower engine!!!!!
IF, and I EMPHASIZE IF, RIGHT AWAY you properly lubricate the compressor [IF it uses crankcase oil] you MAY extend the life a little while longer, but that no cold start, and low high pressure capability suggest that the bearing(s) is/are dragging badly already.
If your compressor is an "oil-less" type, then an overhaul or replacement will probably be necessary.
Jan 10, 2015 | Air Tools & Compressors
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
I have a 21 gallon 4hp peak motor Central Pneumatic oil lubricated Model 47065 air compressor and it will not go to over 20 psi and it will just keep running
Possible that there is leak on the system or the piston/rings/cylinder has worn out.Also check for oil within the unit. Check the compression of the cycle and if this is too low it means that there is wear and tear and will require a overhauling and reset.
Mar 14, 2012 | Air Tools & Compressors
Central Pneumatic 2 hp 8 gal compressor won't build pressure just sounds like leaking all the time where do i start to look for problem
if it is leaking air the check valve is bad.find the airline leaving the air pump follow this line to tank.this line attaches to the check valve which is screwed into tank.make sure no pressure is in tank when removing.
May 18, 2010 | Air Tools & Compressors
Poter-Cable 135PSI Pancake Compressor
Check the pressure switch, they can become stuck in the open position. You can jump it to see if it is functioning or use a multimeter if you have one. Assuming that you've oiled and taken care of it it is unlikely that it simly quit, but that could happen... check across the poles of the motor for continuity which will tell you if the electric motor is blown. ALso make sure the compresor is not seized...
Jan 04, 2009 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
893 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
