Question about Breezaire WKCE 2200 Wine Cooler
Breezeaire wine cellar refrig unit runs too long, frosts up.
I have a Breezaire unit for a 1200 bottle cellar. The unit now runs on for hours, exceeding the temp I set. There is buildup of ice and frost at the edges of the front panel, but still takes hours to bring the cellar to 55 degrees. Is the thermostat no longer working? Thanks! Mark
localwonder
  • 6784 Answers
SOURCE: ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Posted on Mar 11, 2009
  • 22 Answers
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
cpt_cavman
  • 69 Answers
SOURCE: refrig section not cold
thats blockage to frig area....get a cooler and put yer food in it and de frost....should be like new....if not the blower to the lower unit is most likely bad....depending on the age of the unit you might be better off (if affordable) to replace it...
Posted on May 10, 2009
voodoomox
  • 1689 Answers
SOURCE: Frost buildup in the lower left of the refrigerator compartment.
hi srhaus,
all you have to do to resolve this issue is to defrost the fridge by leaving it unplugged overnight.
hope this works for you as much as it did foor most users.
regards,
voodoo
Posted on Jun 18, 2009
  • 35 Answers
SOURCE: excessive frost buildup in bottom freezer section of Kenmore refr
In my case, this happens when the drawer does not seal properly. If I am aware of this, I don not have the snow build up. My problem is why the drawer doesn't always close properly, and it is inconsistent. There is no adjustment. Anyway, if the drawer seal is the slightest bit open, snow-like frost will build up in freezer. Mine is a GE pds20mcrbb
Posted on Jul 01, 2009
Testimonial: "Very helpful description and pictures."
How do you open cabinet to replace fans on a Breezaire WK2200 unit?
YOU WILL HAVE TO DRILL OF THE RIVETS ON THE SIDES OF THE UNIT USING A 1/8 DRILL BIT, ONCE YOU DRILLED THEM OF YOU WILL TAKE OF THE COVER ON THE UNIT AND YOU WILL SEE BLUE INSULATION ON IT, REMOVE THE TOP INSULATION COVER AND FANS WILL BE EXPOSED, THEY HAVE QICK DISCONNECT LEADS ON THE WIRES, DISCONNECT THE WIRES, UNSCREW THE FANS WITH A PHILLIPS SCREW DRIVER, INSTALL NEW FANS AND REMEMBER TO TIE STRAP THE WIRES FROM THE NEW FANS TOGETHER SO THEY DONT MOVE.
Jul 13, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
Refrigerant lose
YOU WILL NEED TO REPLACE THE CONDENSER COIL(HOT SIDE OR BACK OF THE UNIT) AND RECHARGE THE UNIT SAME AS IF THE UNIT HAD A REFRIGERANT LEAK.
COIL IS ABOUT $95
Feb 27, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
Unit is not cooling. there was dust on the coils that i cleaned off. Now the unit wont cool and there is a dot next to the temperature which is 76
UNPLUG FOR 15 MINUTES AND REPLIUG UNIT IT SHOULD RESET UNIT, DOT IS A DELAY MODE FEATURE OF THE UNIT, YOUR UNIT IS NOT A WKC IT IS A WKCE1060
Jun 19, 2011 | Breezaire WKC1060 Wine Cellar Cooling Unit
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
I need a wiring diagram for a Breezaire WKE 8000 wine chiller/cooler. Does anyone know where I can download one?
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Mar 16, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Can you advise what type and amount of refrigerant is in Breezeaire 6000 wine cooler?
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Nov 26, 2010 | Breezaire WKE 6000 Wine Cooler
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Oct 02, 2010 | Breezaire WKL 4000 Wine Cooler
Breezaire WKCE 2200 Wine Cooler Logo
267 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
