Question about HP Pavilion F1703 17" LCD Monitor
I came home to find loads of red squiggles all over my monitor. Then 4 big red vertical stripes that look like bar codes. I tried to restart the computer by turning it off, then as it was starting, loads of little green dots all over the screen, then back to the vertical red stripes. Also, the monitor doesn't go to it's full size resolution...it's like a little box. What's going on?
  • HP Master
  • 3,866 Answers
Wow llks like the controller died in the monitor the controlles the pixalation and stablilization in this case it looks like if its not under warrenty a new one is in order sorry no quick fix I would appricate nice feedback tho
Posted on Apr 23, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
I have red vertical stripes, then white dots, then when windows loads, I have wavy red lines. Using Nvidia Geforce 9800 GT with Pavilion Elite m9350f. Is this my video card problem?
Okay you proved it is the monitor, but first sub the video cord from the computer to the monitor if possible, if okay! at this point you are looking at a LCD panel display problem, cheaper to replace than go through expensive repairs.
Mar 19, 2012 | HP w2207 Monitor
Dark, vertical stripe on copy on Sharp AR-M160
Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
Feb 10, 2010 | Sharp AR-M160 Laser Printer
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
257 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
