How to set to wide screen?
I would like for the picture to be the full size of the screen
  • ariebradley Apr 26, 2009
    Where in the settings can i fix the problem? The remote does not have a Picture Size button, Aspect or Zoom.
    Genius:
  • 1,039 Answers
Look on remote for picture size,aspect or zoom button and press until picture is desired size.
Posted on Apr 25, 2009
  • electroman Apr 26, 2009
    What is the brand and model?
2 Suggested Answers
  • 74 Answers
SOURCE: picture size to wide
I am not convinced that the tv is at fault. The answer may be in the menus of the set top box, if you are using one. If you have cable then put the cable wire directly into the TV to see if the TV is at fault or not. If you have satellite then consider calling your provider to ask if they have a zoom function setting in the box.
Posted on Mar 26, 2008
The full picture is to large for the screen on normal or wide settings.
My Sharp flat screen has VIEW MODE on my remote and that's what I use to change picture size. You did not say your make.
Nov 04, 2015 | Televison & Video
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
Jul 09, 2013 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I have wide screen picture and dont know how to get full screen picture
Some sets in this size range will not format the picture in HD at full screen but only 4x3 or letter box format.
Google the model number with "specs" or consult the owner manual to see what the set is designed for.
Jun 01, 2012 | iLO IWT3206 TV
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Jul 24, 2011 | Hitachi CLU-5713TSI Remote Control
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Gateway P41M`01 Picture off the top and bottom
You should have a button for "aspect ratio" (unsure of your brand of tv), could be marked "screen size - picture format" etc. Cycle through the sizes with this button until you come to auto or wide (set to auto to adjust the pictures to what is being transmitted - wide for a full screen but will stretch the picture to fill when transmitted in 4:3 format)
Jul 05, 2009 | Gateway GTW-P42M102 Television
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
