Question about Kitchen Ranges
Start button not working for my oven, (digital panel)
I have a digital electric range by kenmore and the start button for the oven doesn't work, what would be the problem?
  • 113 Answers
You most likely will have to replace the whole control module
Posted on Apr 23, 2009
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
F1 keeps flashing, top elements work but oven doesn't. What part do i need to replace? I have kenmore electric range
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . Gene
Aug 29, 2011 | Kenmore 75853 Stainless Steel Dual Fuel...
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
My kenmore oven keeps saying f7 and doesn't work
In another posting I saw that a Technical Data Sheet was taped inside the top control panel. I opened it up (two LONG screws mounted vertically in the top of oven door) and was able to access the Technical Data Sheet. It DOES have all the "F" codes listed, AND instructions for setting many variables within the oven. CAUTION: !!!! if you are NOT experienced working on ribbon cables, the delicate connectors and in close proximity to "hot" wiring... I DO NOT recommend attempting this... Call a repairman or find someone who IS familiar with all of the above.
May 22, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
186 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
