Question about GE Refrigerators
My refrigerator will not shut off until we tap the temp dial
  • 358 Answers
If the temperature in the refrigerator is ok you have to replace the cold control.
Posted on Apr 23, 2009
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
My fridge keeps freezing all the food. There is no manual for the fridge unfortunately. How do I know on what the dial should be?
Move the dial to a warmer setting and put an expensive refrigerator thermometer in to monitor the temp. Adjust the dial until you get it where you want it.
Jun 02, 2015 | Refrigerators
Do I turn dial to right or left to turn up temp on nova kool RDS7500 fridge
Turn the knob all the way until it shuts off, then turn to the opposite direction for lowering the temp. :-)
Jul 20, 2014 | Refrigerators
Red dial On A Amana bx21
If the fans are not coming on that would tell me the defrost timer=> R0131577 Defrost Timer is worn out and or stuck in defrost. Turn that red dial clockwise slowly until you hear compressor and fan restart.. If this solves turning on the refrigerator then you will need to replace the timer with the red dial because the clock inside is stuck and will contine to cause problems until replaced. Let me know if you have questions, Thanks Sea Breeze
7_8_2012_6_48_53_pm.jpgR0131577 Defrost Timer
Jul 08, 2012 | Amana ARB8057CSR Bottom Freezer...
My refrigerator keeps turning off
It could be a defective defrost timer if you have lights and NO fans running nor compressor starting you maybe able to tell if it shut off about every 5-8 hrs. Now if it shut off after every cool cycle then I would tap the refrig temp control with a firm tap if the frig starts then it is a defective operating thermostat.
Apr 09, 2011 | Refrigerators
Refrigerator keeps running The compressor is not shutting off regardless of how cold it gets. If the temp is set at 35 for the frig and 0 for the freezer, the compressor keeps running even when the temp...
your cold-control that you adjust has gone out,be it dial adjust or electronic unplug the dial one and see it will shut down,be careful on unplugging on an electronically controlled unit as you can ruin the control board if not powered down before board is unplugged
Jul 27, 2010 | GE Refrigerators
My refrigerator only kicks on when I adjust the temp knob.
You need to replace ( or have it replaced ) , the thermostat . The piece the knob pushes onto . The liquid is seperated inside the thermostat cap tube , causing the internal contact not to close . Also , a tap on the knob , will start the refrig , until it reaches temp , but then may not restart until another tap . Replace it and that will solve the problem .
Apr 20, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Food in my refrigerator freezes I have a top freezer maytag
There are 2 things to check - Your cold control dial - to rule out a thermostat problem lower it to 1 gradually and slowly until you hear a click and it shuts off - If it does not shut off, and only shuts off if you set it to the OFF position, then you have a thermostat problem and your compressor is continually running, freezing things in your refrigerator. If lowering your dial you hear a click and compressor shuts off, then the solution is to lower your dial, you have it set too cold - There is a thermostat in your refrigerator that should shut things off when it is cool enough it's either not working properly or your dial is set too cold.
Sep 05, 2009 | Refrigerators
HI: We have a 6-7 yr old TRUE single door, stainless steel fridge. We noticed yesterday ..that at "4" on the temp dial, the fridge is freezing milk in glass gallon jars. We backed the temp down to "2" and...
With the refrigerator, the fan inside the conditioned space should always run. This is normal for most all commercial refrigerators. Need to check to see if the unit is shutting off the compressor after the conditioned space reaches a good temp, usually 35 degrees. If not, probably a bad thermostat.
Apr 11, 2017 | True Food VWR Storage Refrigerators with...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
