Question about Garden
When i tighten bolt cord wont return - Garden
    New Friend:
  • 93 Answers
Bad Spring Housing or Upside Down, We need a little more info !
Posted on Sep 15, 2009
Why wont the pull cord return/
use graphite powder in the spring and lock palls undo the lock screw and place a small flat washer between the cover and the body to give the return spring more room to move when the screw is tightened up.
Dec 04, 2014 | Cars & Trucks
Pull cord not grabbing
The Dogs inside the Recoil are worn or Dirty is my first idea. But it could also be a loose Recoil also (This happened to me and my Ski Doo XP.
I purchased a new Recoil just to find out that 3 of the bolts were missing. Got new bolts and tightened it up and returned the Recoil. Ski Doo's Recoil Rebuild Kits do not last very long.
Nov 12, 2013 | Polaris 2010 WideTrak 600 IQ
How to pull a thermostat and where is locateed
Assuming you have the 2.7 liter engine, the thermostat is where the lower radiator hose returns to the engine.
2.7L Engine
  1. Disconnect negative cable.
    CAUTIONDo not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  2. Drain cooling system.
  3. Remove radiator lower hose from thermostat housing.
  4. Remove nuts from heater tube flange studs.
  5. Loosen starter bolt at heater tube bracket.
  6. Pull heater tube out of thermostat housing and position out of the way.
  7. Remove bolt and two studs.
  8. Remove thermostat housing, O-ring and thermostat.
  9. Remove thermostat housing bolts.
To install:
  1. Clean gasket sealing surfaces.
    NOTEInstall thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  2. Install thermostat and seal into thermostat housing .
  3. If removed, install two studs.
  4. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  5. Lubricate new heater return tube O-ring with coolant.
  6. Position heater return tube flange over two studs. Install nuts.
  7. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  8. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  9. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  10. Refill cooling system.
  11. Inspect for leaks.
  12. Connect negative cable.
Mar 18, 2012 | 2001 Dodge Intrepid
Starter bolt wont tighten down on top of mitshubishi eclipes 2002 4 cylinder is it suppose to have a nut on the end
no, i am guessing you bought a rebuilt starter,in many cases they strip out if its a new starter return it if not you will have to remove it and heli coil it .
Sep 06, 2011 | Mitsubishi Eclipse Cars & Trucks
How to get the front wheel off my 1996 Nissan Sentra
Just get a 12" tire wrench and and unscrew the bolts and the rest is easy. In returning the wheel, however, make sure to tighten the bolts alternately from one side to another so that the wheel mounts balanced. Do not tighten it first, tighten them after all the bolts are in position and the wheel is balanced.
Dec 19, 2010 | 1996 Nissan Sentra
Belt is off center
Tighten the rear adjusting bolts until the walk belt it tight enough to lift about 1.5 inches at the sides of the walk belt. After you do this, Turn the treadmill on to speed setting 2, and be ready to tighten the side that the belt is closest to.( if the belt is against one side, start with that side) Tighten only 1/2 a turn at a time and watch the belt start to move. It wont take much once it starts to move. Only tighten each side ( if necessary) dont loosen the bolts. Once the belt is in the middle, leave it alone. The belt is now adjusted. You may see it travel to one side, breifly, but it will return on its own.
Hope this helps
Nov 10, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
Pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
Jun 09, 2009 | Garden
they spring clip is broke, you have to take the head off and reconnect. You have to get a new head or spring, depending on which one failed. Good luck
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
