Question about HP Compaq Proliant DL350 (345101-001) Server
We have HP proliant 380G5 server with Microsoft windows 2003 installed what additional hardware & software is required to make it as a Database server
  • 4 Answers
You need a database program - Microsoft SQL, MySql, Access, etc... Setting up RAID will help your speed.
Posted on Apr 23, 2009
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
My server is keeping booting and can't log in to windows
You issue could be both hardware and software related. The Blue Screen of Death is one that I don't like to see but can be easy to solve at times. First, I would recommend you recheck and hardware that was newly installed; memory cards, cables, etc. Verify they are connected or inserted correctly. Next, if this is a new install of Windows 2008, verify that your server meets the hardware captiablity for S2008. (Remember, this is a 64-bit os and you will need drivers if your server is 32-bit based.) You can find this out by inserting the Windows Server 2008 boot disc and run the Check System for Compatiablity function from the menu.
If you are certain that you have no hardware issues and the install was performed correctly, you may need to reinstall Server '08 and monitor the install for any exceptions that may occur.
Good Luck,
C2Solutions
Nov 25, 2011 | HP ProLiant ML110 Server
The server making restart every few days making restart all the night i make hardware diagnosis and found no problem windows server 2008 SP2 installed
Do a power audit on the power goes into the server. Use Microsoft Malicious software removal tooi to check for Malicious software.
Sep 11, 2011 | HP ProLiant DL580 G5 (438087-001) Server
The software will does not be installed on this system because the required hardware is not present in the system or the software/ fimware doesn't apply to this system (OS is windows 2003 Enterprise...
It sounds like you are trying to install software that was made for a more recent edition of windows. You need to get the version for your OS.
May 03, 2011 | HP ProLiant ML110 Server
Hi i have HP Proliant ml 150 but i cant install server 2003 . how to install windows server 2003
Windows Server 2003 or Windows XP x64? They're the same operating system as I understand it. You must have 64 bit hardware installed on your computer to run a 64bit operating system.
What errors if any are you seeing when you attempt to install this OS?
Feb 16, 2011 | Computers & Internet
I am using ProLiant ML110 Server i wont to use windows xp how to find the driver for xp
ProLiant ML 110 server series does not supports windows XP. It Support only the below OS.
  1. Windows 2000
  2. Windows 2003
  3. NetWare 5.1
  4. NetWare 6.0
  5. NetWare 6.5
  6. RHEL 2.1 (32 Bit)
  7. RHEL 4 (32 Bit)
  8. RHL 9
  9. SUSE Linux Enterprise Server 8
If you want to force this hardware to support windows XP, then download windows 2003 drivers which is equivalent to XP; but not the same as XP.
WINDOWS 2003 DRIVER LINK
Regards
Riztech
Nov 29, 2010 | HP ProLiant ML110 Server
I have HP proliant Ml110 g5 server and i want to install Windows Xp insteadoff Windows server 2003. i have a driver which is compatable with windows Server but not windows xp. so what can i do for that.
visit my site
www.sureshayyar.110mb.com
for all installation issues of XP....detailed instructions can be found to install XP there...browse all pages there....
which driver are u looking for and which one you have for what hardware ?
Mar 27, 2010 | HP Compaq ProLiant ML110 G4 Server
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
HP Compaq Proliant DL350 (345101-001) Server Logo
119 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
