Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch Nexxt washer will not spin
The washer will not spin, but will drain and fill with water. Clicking sounds coming from the washer, sounds like solenoids or something trying to engage. Unplugged item overnight, and tried again next day, still does same thing. Any ideas?
  • kbcleaner Nov 24, 2007
    we are also having the same problem if you have a solution please let me know.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
We solve it ... the problem was in the module..( control panel ) .
Posted on Oct 30, 2008
RE. Bosch Nexxt 100 series. Does not spin. I have cleaned all hoses, outflow and inflow. Opened the little circle door at bottom right and it is clear. The fan even spins during drain cycle. I do hear...
Check connectors on motor assembly they can become loose due to the high speed and vibration. Motor and drum are tied together. I had similiar problem with mine after spending a few hundred on a control board which made no difference.
Oct 12, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water will not drain out of washer (bosch nexxt 6400). Will spin if on cold wash but not on spin. makes a clicking noise while trying to drain
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Mar 14, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Fill up the tub but never spin and then drain, suggestion please?
The same issue occured with me. I spoke with Customer Service as the unit was still warrantied at that time. A Technician come out; his experience was common with this Bosch unit as he had learned over the months that Bosch has sub-contractors that supplied faulty and/ or sub-par circuit boards and components. This particular board was replaced and the incident did not recur.
Mar 21, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
208 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
