Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
55 Inch Projector Toshiba 55hx70 powers up but no picture
Set powers up but no picture, power button light stays/flashes red
  • jbowe438 Apr 24, 2009
    I sorry i gave the wrong information, this is a rear projection screen TV not a projector. The model number is correct
  • Anonymous May 10, 2009
    the tv truns on then the power button bliks blue then truns off. no picture, no way to access the menu. i am lost please help me fix it;)
    New Friend:
  • 58 Answers
Replace the lamp
Posted on Apr 23, 2009
Tip
Toshiba 55HX70 Service Manual Download
Download Toshiba 55HX70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 55HX70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55HX70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 55HX70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 55HX70 Manual Download
on May 10, 2010 | Toshiba 55HX70 55" Rear Projection...
Tip
Download Toshiba 55HX70 Projection Television Manual
Have you misplaced your Toshiba 55HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 55HX70 Projection Television instructions.
I hope that helps.
How do i adjust convergence on a 55 inch toshiba
You need an original working Toshiba remote: two choices here--in the customer menu there will be an option for this and there is a hidden tech menu for finer adjustment all over the screen.
Usually the customer mode works ok--if you find red or blue will not adjust somewhere you have a problem-that aside tell me what you are trying to acheive?
SD TECH
Dec 12, 2009 | Toshiba 55HX70 55" Rear Projection...
Why does the power light flash on my tv after 15 seconds when i turn it on for sometimes 2 or 3 days.
Hi, this is heat related. you will need to replace the fans in this unit. this will fix this issue. also, inspect the ballast in the lamp area. if it clicks when you are powering up more than 3 times, the high heat may have damaged this circuit that provides the power to the lamp.
May 20, 2009 | Toshiba 55HX70 55" Rear Projection...
Toshiba 55hx70 projection tv problem
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Jan 20, 2008 | Toshiba 55H70 55" Rear Projection...
Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
Jul 28, 2007 | Toshiba 55HX70 55" Rear Projection...
55HX70
needs convergence ics period
Nov 24, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55hx70
check all the fuses. Its easy to mis the 2amp pico fuse mounted near the middle of the power board. When this fuse opens, the red at the top, especially at the left side of the screen, will not adjust enough. Be sure to use new heatsink compound behind the ic's Shutdowns,are usually,not an easy repair Good luck
Jan 31, 2006 | Toshiba 50HX70 50" Rear Projection...
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
461 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
