Question about Kenmore 22422 Top Load Washer
When my washer drains, it is backing up into my bath tub.....
Then the water is leaking out under the tub and into our hallway (we are on a concrete slab). I tried the baking soda/ vinegar drain solution and it worked for a couple of weeks, but it is now doing it again and the baking soda/ vinegar solution is not helping this time. Any thoughts?
  • julesw625 Apr 23, 2009
    Disregard this one....this is not the washing machine that I have. I have reposted the question under general washing machine info.
  • 3 Answers
Sounds like a plumer probllem.
Posted on Apr 23, 2009
Do i use a washer between the tip toe assembly and the tub
Use plumbers putty between the assembly and the tub on top. Use the rubber washer underneath to mount up to tub.
Rubber washer on top may work but due to hot temperature water it would cause the rubber to loosen up and cause a leak.
May 31, 2010 | Plumb Pak & Triad Bath Drain
This might be a plumbing problem but it only happens when I do a load of washing. When the water drains it goes into a pipe in the wall and then my bath tub fills up, and the bath drains .When the water...
Check your main vent line for obstructions (animals, nests, leaves, etc.) and then have your drains inspected. There is likely a "log-jam" (pun intended) in the sewer drain line - as it is not allowing the water to drain as fast as the washer pumps it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2010 | Washing Machines
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Water is leaking from bath tub drain
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
Apr 26, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Mar 20, 2009 | Kohler Overture 5ft Vikrell Bath -...
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer Tub Fills With Water When Washer is Not On
I suspect you have a water inlet valve problem. When the valves fail, they tend to either leak by, or do not open at all. The symptom you are describing is typical of an inlet valve that is not closing properly. The leak may be minute, but over time, it fills the tub and over flows. To access the water inlet valve, you will need to remove the washer top panel. Remove the three screws in the back that hold the top in place and slide the panel straight back and lift off. The water inlet valve will be located on the left hand side in the rear between the fill hoses and the dispenser (as viewed from the front of the washer). If you wish to perform this repair yourself, you can find the part at searspartsdirect.com. Just type in your complete model number and the part can be located on the next page under the "Dispenser Parts" section as item number one (part #8181694). The replacement process is very simple. Just turn off the water source, remove the fill hoses, the dispenser hose and the mounting screws. If you need further assistance, please let me know. I hope this helps you.
Jul 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Jan 20, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 22422 Top Load Washer Logo
601 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
