Back to:
Tags:
D-Link AirPlus G Wireless Range Extender DWL-G710  Repeater
D link airplus G Wireless range extender
posted by nascar29 on Sep 24, 2007
I purchased a D link wireles ranger extender model DWL 710 G but I cannot get it to work.
The unit powers up fine and I seem to be able to connect to it as a wireless network using a linksys card in my laptop BUT. It appears that it never connects or talk to my Linksys wireless router. I connected directly to it using an ethernet cable and have tried to ping the default I.P address but get no response. I have reset the unit using the reset button on the back several time but still get nothing. The unit does appear to be transmitting as it shows up as a wireless network. Also, I am in the country and have no security or anything turned on in my network. It is running wide open. As I read all the info I belive this unit should connect on its own and talk fine.
Any insight would be appreciated.
rlt.
Comment by nascar29, posted on Sep 24, 2007
Already tried that one. Does not seem to make any difference. Sorry I did not mention it originally
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
PyroMan6x9x9
Rank:Guru Guru
Rating: 93%, 457 votes
Try using a crossover cable, this is special ethernet cable where the internal wires cross, this is needed for router to router or computer to computer.
These can be purchased at any electronics store, or if you have an extra cable follow this link for a how to make one yourself.
http://www.makeitsimple.com/how-to/dyi_c...
Good Luck
Rating Locked! (?) nascar29 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on D link airplus G Wireless range extender:
I don't want to Accept this solution
Solution #2
posted on Oct 25, 2007
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You have to change your computer IP address to the same domain as the range extender i.e. if your range extendr's IP is 192.168.0.31, try setting your computer's IP to 192.16.0.xx where xx is between 0 and 255.
Cheers,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Nov 14, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
you should first configure your repeater to actually find and repeat your wireless router's signal. Then you should be able to connect to the internet
Thank You!
Can you Help with these Networking Repeaters problems?
D Link hub failed and switched to a BT Home hub. I have 3...
D-Link AirPlus G Wireless Range Extender...
i am having propblem with dwl-1200 ap i cant make it work...
Have tried many excercises, need units on line ASAP....
I bought `Conceptronic wireless 54Mpbs Access point´...
motherboard drivers
Loading problems.
Repair Service
Find Networking Rep. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
