Question about MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV Monitor Car Video Player
Marantz plasma monitor half black - MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV Monitor Car Video Player
It's either gonn'a be one of the horizontal buffer boards going from top 2 bottom that are connected 2 the y-sustainer or the one of the 4 inverters is bad on the y or z board. most likely the y board just check 4 tempeture indifference
Posted on Sep 12, 2009
I moved my marantz plasma tv and now it wont turn on
Some of these have a master power button on bottom or rear, larger square push switch, it may have got turned off from power there....
Dec 15, 2012 | Marantz PD-6140D 61 in. HDTV-Ready Plasma...
MARANTZ TV _ XBOX connectivity:I have a Marantz PD5040D TV with plasma monitor. A Foxtel blackbox is connected to it so that I can view about 20 Channels. This works well. I now want to connect an Old Xbox...
Yellow= video lead - connect to either terminals C (have you tried all 3?)
Red/White = audio leads - connect to D
Make sure source<on remote> is set to correct video terminal <1,2 or3>
If that doesnt work perhaps try the yellow cord going to either of terminals F untill you get a picture... but it should work!?
May 07, 2017 | Televison & Video
Black screen
first try the address board or buffer board.if this
does not repair it,the panel is defective.
Jul 17, 2009 | LG 42PC3D 42 in. Plasma Television
Top half of screen doesn't show video, just menu
replace the main pcb also called the digital pcb.you also could have a defective address or
buffer pcb that feeds the top of the screen if the top is black.if screen is not black.replace the main digital pcb.where all video is done in
the tv.
Jul 15, 2009 | Televison & Video
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Dec 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Computer input to Marantz 50 Inch TV
You will need a VGA to HDMI converter, at least $100. Just Google it and you'll find one. One is linked here: http://www.hdtvsupply.com/vga-to-hdmi.html
Aug 16, 2008 | Televison & Video
Marantz PM-74D
Your no doubt finding the speaker safety/turn on surge protect relay NOT engaging a few seconds after turning it on-right? Check the output transistors. These are the big green and black ones screwed to the heatsink. You gain access to them by taking off the bottom cover. There's 4 per channel--2 green and 2 black. You'll probably find one or more of them shorted. If you find replacements, put them in exactly as the originals with new thermal grease/heatsink compound. Unsolder and lift the center pin (collector) on each of the four transistors of the effected channel. Power it up and check across the outside pins of each device for proper bias-about a half a volt or so on each one. If the voltage is much higher, or not there you've got other problems that will require more diagnostic/troubleshooting. Do all the lights on the front panel work-or just the tape monitor indicators? If just the tape monitors light up, check resistors RN83 and RN84 on main board under the speaker connector board-remove the speaker connector board to get at them. These are bad on mine and I've yet to replace them. I believe these to be 920 ohm 1% precision resistors....
May 17, 2008 | Marantz PM-68 Amplifier
MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV Monitor Car Video Player Logo
116 people viewed this question
Top MT&V Car Audio & Video Experts
xxxxxx xxx
Are you a MT&V Car Audio and Video Expert? Answer questions, earn points and help others
