Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Scenium HD52W140 smoked
Hi, My RCA rear projection tv literally smoked. My dad is is an electronic engineer so we took out the high voltage board and there is a resister that is black and burnt on the board. He said he is certain that is not the only problem, but we can't find a schematic for this tv. Any idea where to find the repair manual or schematic? Or would u know off hand what specific parts to look to replace before we put the board back into the set? The model # on the set is: C357C8011T. Actually a previous service guy added the "T" to the end of the model number, so not sure if that is part of it or not. Believe it or not, this is the 2nd tiem this set smoked and almost caught fire. Not a good product at all. But the first time it was under warranty. Thanks, Aaron
    Genius:
  • 1,139 Answers
Hello Here is a link to get the schematic for this set: http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=%20D52W20 Thank you
Posted on Sep 24, 2007
How much does it cost roughly to get this problem fixed. It just happened to me. Thanks..
Posted on Oct 08, 2008
More than likelly, you have a bad HV splitter, or a bad tube. What happens is that if the high voltage is shorted to ground the flyback will backfire and burn the abl resistor. My sugestion is to replace the resistor and disconect the flyback hv lead from HV splitter, if it does not smoke again then ck the splitter to graund, with your ohm metter, is no supposed to read any value.
Posted on Oct 03, 2007
SOURCE:
My tv starts scrolling through video modes,and the menu screen constantly flashes on and off and i turn up the volume and it goes back down by itself,any thoughts how to stop this would be very helpful...
Thats caused by the Small signal board. which is the green board on the right side with all the inputs on it. Thats a very famous issue for RCA rear projection models.
Nov 07, 2012 | RCA HD52W140 52" Rear Projection...
When I press the power button the tv will make an attempt to come on, then go back off. it would do this about three times then stay off. each time it makes an attempt to come on, it would make a high...
The high pitched whine is indicating there is a deflection board issue which is preventing the set from powering up. Rplacing the deflection board should solve the problem. You can get the deflection board from www.tvrepairworld.com
Aug 09, 2011 | RCA HD52W140 52" Rear Projection...
TV makes very loud noise
Ur high voltage transformer is dead,the FBT,the big block of plastic have red wire go to the video board.Also might have burns capacitors in the DM power suply board or deflection board it puffed up.
Sep 28, 2009 | RCA HD52W58 52" TV
Rca d40 w20 lost component "spark gap"
Yes they are spark gaps and no when bad high voltage will arch out of them, Go to Cp150 2200uf 16 capacitor if it is puffed up on top it is bad .you have 3 that need re[lacing cp114 cp120 cp150
Jan 09, 2009 | RCA Scenium D40W20 40" Rear Projection...
Tv problem dead set
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
http://servicemanuals.vstore.ca/
May 20, 2008 | RCA HD52W140 52" Rear Projection...
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
HD65W20JX1 RCA SCENIUM THOMPSON MULTIMEDIA
looking for an owners manual for the D52w20 RCA 52 Rear Projection TV.
[email protected]
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Jul 24, 2006 | RCA Scenium D40W20 40" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
408 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
