Question about Wolfgang Puck Rotating Waffle Baker - Silver
It powers on but it doesn't heat up anymore!!!
Well this item powers on but the waffle pan doesnt heat up anymore!!!
  • 33 Answers
Sounds like your element is bad, or is not connected
Posted on May 21, 2009
Won't heat up
Replace Thermal protector fuse. eBay item: 161159856383 $1.99 free shipping. Comes with physical crimps, just cut out old fuse and install new one. Works fine.
Apr 19, 2014 | Waring WMR300 Belgian Waffle / Omelet...
Waffle iron not heating
see this steps and fix it. God bless you
f the appliance does not heat, make sure that power is on at the outlet and test the electrical corrd , replace it if needed. If this doesn't work, disassemble the unit and test the heating elements.
If the appliance does not heat to the proper temperature, check the thermostat contacts. Some cooking appliances have an adjustment to reset the temperature ranges; you'll need the owner's manual to do this job.
Oct 15, 2012 | Hamilton Beach 26500hb Waffle Maker...
I have a model 8550. The waffles ndon't bake completly at the highest setting.
It won't bake anymore because its heater, thermostat, loose wiring either of that three I mentioned will cause no heat, no bake symptoms. Have it check if you can or find a service technician.
That answer your problem.
Mar 31, 2011 | VillaWare Kitchen Appliances - Others
Why does the waffle stick to the maker and how do you clean it???
Waffle pans are seasoned through usage. If you clean the pans too well, they won't work right. It's a bit like cooking with a cast iron skillet. If you wash it with soap and water, you strip the oils off of it, and it will rust.
Use some Pam or similar product when you get ready to make your waffles. Spray the lower pan, add your batter, and then spray the upper pan. Close the waffle maker up quickly after spraying the upper pan.
To clean off old material, it's easiest to scrape it off with a nylon scraper, taking care not to score the metal. A bit of the cooking spray will help on the most stubborn baked on material.
I personally prefer to use the batter that requires the addition of cooking oil, and I still spray the pans as well. This leaves me with a seasoned waffle making machine.
When you've finished with the waffle machine, wipe down the outer surfaces with warm soapy water, followed by clean water. Clean the pans the least you can. Usually, if the waffles are leaving little to no residue, we just wipe the pans clean with a paper towel, and then put it away.
By the way, the first waffle in any given batch seems to never be as good as the ones that follow. We call this one the "sacrificial waffle" and move on. Our dogs appreciate it!
Best regards. Hope that you found this somewhat helpful. --W/D--
Jan 30, 2011 | Waring WMK300 Professional Belgian Waffle...
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
The waffle iron won't heat up.
Hello kor..... Check the outlet that you are plugging this item into. These draw alot of power so you may have kicked a circuit breaker or blown a fuse. IF that is not the problem, then the heating element in the waffle iron is probably bad and needs to be replaced. Since it is a waring, fo to searspartsdirect.com
Enter the model number and you will see the parts diagrams and be able to order parts. Joe
Thanks for choosing Fixya!
Jan 17, 2011 | Waring WMK300 Professional Belgian Waffle...
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
No heat
It will initialy take some time to heat, but if it doesnt become hot in 3min or so.. then make sure voltage is properly fed and also check for any switches or reset button. If all this doesnt work then it means the heating coil inside wud have been cut or fused.
Thankyou
Feb 10, 2008 | Waring WMK300 Professional Belgian Waffle...
Wolfgang Puck Rotating Waffle Baker - Silver Logo
222 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
eyecam
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
