Question about Refrigerators
Refricerator/ Frezer is on and runing but not frezing or refricerating
Hi, My model # csf22m refricerator/frezer stop working.Its on and runing but not frezzing or refricerating.
  • carlgri2 Apr 23, 2009
    Thank you so much. That solved my problem. Thank you.
    Carlisle,
  • bkbahughey Apr 23, 2009
    I have an Admiral HMG211440. Can hear both running, it is making ice, fan is working. It is not defrosting and certain items are not as cold as they should be...milk, cheese...in freezer..cubes are frozed but icecream is not froze. any ideas are appreciated can't afford service call
  • Refrigerators Master
  • 4,654 Answers
On front of refrigerator and near floor remove kick plate and look for a small box with a hole in center. If you find the part I want you to turn the center clockwise slowly until the refrigerator stops or starts. I may be stuck in the defrost position. If it begins to work we need to replace the timer. Let me know what you find, Thanks, Sea Breeze
Posted on Apr 23, 2009
  • John Tripp
    John Tripp Apr 23, 2009
    You are very welcome, just make sure to change the part your turned, that is your defrost timer...Sea Breeze
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Water leaking into bottom of frezer,water frezing on bottom then leaking onto floor
defrost drain bottom rear of freezer is blocked . Defrost and clean drain tube.Poor water in trough at back under rear panel. If it drains out quickly then it is clear.
Oct 29, 2010 | Frigidaire Kitchen Ranges
Ge model # tff34rvf refrigerator runs then shuts off for a long time. frezer makes ice and frezes items then things thaw agan
run times are to long . caused by dirty cond coil or fans running too slow . clean coil first this may correct problem . if not , the the cold control may be failing so replace it next .. and clean it reg . as it will nt cool when dirty .. mm
Jan 07, 2010 | Refrigerators
The freezer is really cold, not freezing and the refrigerator is not working at all....any suggestions? I have an Avanti refrigerator.
the problem is in your frzer unit check that the fan in the frezer is runing that will drive the cold air to your fridg side...
www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I was pickeing away at the ice on frezer and i poked a hole in the plate for the frezer, i need to know if the fridge will still work or do i need to bye a new one
Yes , should still work as long as you didnt hole the coolant pipes. Use some putty or similar to block the hole.
May 19, 2009 | Refrigerators
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
