Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
SimpleTech Pininfarina: I/O error message, then it stops working
I thought it was the usb port in my computer, but then i hooked my flash drive to the computer and it read. All that I get from the drive is the spinning blue light when you turn it on, and then a red light blinks about 7 times and that's it. The last thing I did was delete a bunch of junk files I didn't need, which caused my computer to stop responding. After that, I've got an I/O error message, and then my hard drive stopped responding. Someone PLEASE help!!! All my recording studio files are on there & without those I'll be in debt : (
  • 4 Answers
SOURCE: Simpletech 500 GB drive won't work (repost because not solved)
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Posted on Apr 22, 2008
TomSolomon
  • 50 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Posted on Jun 21, 2009
SOURCE: simpletech 500 GB drive won't work
Open your Simpletech by removing two screws from the back --> you need to remove the label in the back, and pull the I/O card up towards you. The I/O card comes off easily.You need to buy a BYTECC USB 2.0 to IDE/SATA ADAPTER Kit ( you can buy this adapter on line, It ranges from $16 to over $30). Now connect the USB port from the adapter kit to your USB port, and plug in the Adapter kit to a 115 volt power outlet. If the hard drive is not shot, that is, you feel it spinning, you should be able to see the drive, and copy the data from your SimplechTecj drive to your PC.
Aram Dodakain
e-mail to adodakian@bakerbro.com
Posted on Nov 12, 2009
  • 1584 Answers
SOURCE: changed internal harddrive and now, computer
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Posted on Dec 23, 2009
JulesPCaut
  • 702 Answers
SOURCE: I pug in my simpletech pininfarina 320 GB and muy
I had the same problem some time ago. Have a look at these tips on how to fix external hard disk problems, maybe it helps you too.
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Posted on Dec 28, 2009
Simpletech SimpleDrive will not recognize on my computer, have tried it on another computer and even bought a new USB cable and new computer battery still no luck. I have years of pictures and videos on...
Not Enough power To Run The device Please !! Make sure your USB Is upgraded To The Latest or It wont Work!!! Need More Info !! Hope This Helps Donald Deane MCSE,ASE,CPO
Jul 27, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
Won't recognize external hd
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Not recognized
Make sure that the connectors are inserted properly. Try another cable or see if it mounts on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Lost instruction booklet fo simpletech 250 ex hd
The drive is USB. To access the drive, plug it into a USB port of the computer.
The drive should be recognized by the computer.
I am not sure about Simpletech, however, most drives do not have an "instruction book".
What are you looking for in this documentation?
Dec 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
SimpleTech 320GB Hard Drive- unable to detect the device
Mar 15, 2008 | SimpleTech Pininfarina 80GB External USB...
Simpletech pininfarina problem
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Jp
Dec 05, 2007 | SimpleTech Pininfarina 80GB External USB...
Computers & Internet Logo
132 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
