Question about Sony KP-61S75 TV
Picture goes out periodically
The picture will become yellow and distorted and stay that way for a few minutes to a half hour then come back to normal. I don't know if there is an inexpensive solution before I am forced to buy another TV. Doesn't happen everyday, but enough to be a concern. Also don't know if it tends to happen only if it has been on a while, but would assume when it has been an hour or more. Thanks for the help.
  • Goot Sep 24, 2007
    We did some research on line and looked like it may be the IC that needs replaced and it looks like it would cost between $300 - $900 with labor and parts. My wife believes it was more black and white than yellow.
    Genius:
  • 1,153 Answers
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Posted on Sep 24, 2007
The Picture on my x box goes distorted and pixelated
yes but an hardly wet towel on it then leave it for 45 mins
Feb 19, 2010 | Microsoft Xbox 360 Console
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
Jan 24, 2010 | Philips Magnavox 27MT5405 TV
Picture goes diagonal
U know how to solders?Ur convergence it dead,must replaced.Tries these websites for convergence kit.Tv repair World.com,Tv repair kits.
Nov 13, 2009 | Toshiba 50HM66 52" Television
Picture has shadowing or ghost like images
This unit is getting distortion form the video circuits, most likely capacitors or resistors causing distortion to the input or output circuits. This problem could be caused by a bad video amplifier also ,which is distorting the signal. This problem needs to be checked with an oscilloscope to follow the signal path and find the source of the distortion. Usually this is best handled by a service center. If the unit is still under warranty call this number for Insignia customer help : 1-877-467-4289. If the unit is not under warranty, you should take it to a service center and have an estimate of the problems and repair costs. You can find parts for this television at the Best Buy parts website. Just google it and put in the number of your television and it will list all available parts and prices. You can also call this number for Best Buy parts : 1-888-237-8289. Hope this helps you with your problem.
Apr 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Blinks on and off
Phil, from your description it sounds like your convergence IC`s are about to fail, the intermittent off/on cycle is because as they heat up there drawing too much current, the bowed collapse tells me it`s the vertical convergence IC that`s the culprit. You need to get a tech out asap to fix this or they could short and take out the power supply as well and that`s just mooore money to fix it, hope this answers your question, BMW Rider
Dec 05, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Sony KP-61S75 TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
