Question about HP Officejet J5780 All-In-One InkJet Printer
Can one scan and send from the J5780
Currently I am first printing then inserting printed copies in scanner for scan and send. I realize from reading questions that scan and send is possible but cannot find any how to reference.
Thanks,
Aging neophyte
  • 741 Answers
It has to be an option you received with your scanner..not all scanners are equal. If you can find the documentation on the manufacturers website it will tell you if you have this feature..good luck...
Posted on Apr 23, 2009
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
Well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
Aug 02, 2010 | Office Equipment & Supplies
Says scanner failure, scan, copy and fax will not work, did the print alignment still not working Only the printer works
try use a high quality usb cable, some usb cables has low bandwith, and give some strange, errors like scanner error, copy,...
Feb 09, 2010 | HP Officejet J5780 All-In-One InkJet...
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
HP J5780 - Using scanner with print server
no, print server is just that, print server is only good for printing. I don't know if there are a device you can use for all-in -one office machine. I am looking for one myself.
May 29, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
yes. this printer can be use for wirelss connection, so it can be use with wired jetdirect. however, you are going to need the web jetadmin from hp in order to reconfigure the IP address for the jetdirect.
you can download a copy form HP.com
Jan 13, 2009 | HP Officejet J5780 All-In-One InkJet...
First time scanning
greetings.
To send copy of printed documents to others, follow the steps below.
1. use your scanner to scan your printed documents, save it to jpg format.
2. Use your email to send the pictures.
login to your email
compose or create the message
attached the images
send.
Hope that helps.
Jan 06, 2009 | HP Scanjet 4400c Flatbed Scanner
HP Officejet J5780 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
