Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking underneath Water is leaking underneath and spraying against side of washer. The drain hose has been replaced. Now when filling with water, it does not detect the water level and fills to capacity. what to do?
  • 9 Answers
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Posted on Apr 24, 2009
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
Errpr code 4e on samsun aqua jet vrt
A 4E code on Samsung washers means that the washer isn't filling properly or the sensor isn't detecting the water flow. First, make sure that the water shut-off valves are open. Next make sure that the drain hose outlet is positioned above the fill level of the washer. (This avoids the water being suctioned out of the tub.)
Turn off the shut-off valves and disconnect the fill hoses from the washer and the valves. Clean the filters in the washer and at the valves. Reconnect the hoses to the valve and place a bucket under the other end. Open the valves and check that you have good water flow from both hoses. You may want to replace the hoses. (Some washer fill hoses are designed to clamp shut if they detect a leak. This anti-burst feature will reduce the water flow to a trickle. Since the washer fill sensor detects the amount of water in the tub within 8 minutes, that will trip the error.)
If the washer isn't filling and there is plenty of water coming from the water line, the fill valve probably failed in the closed position. If the water level is rising, then the sensor is probably faulty.
Please add a comment with the full model number of your washer. Then I may be able to point you to the parts. If the washer is under warranty, contact Samsung.
I hope this helps.
May 01, 2015 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
My machine keeps filling and draining. I've had
Hi.
If the machine keeps filling and draining, then there is overflow detected. Rather than going for the control board you should have checked inlet, drain system and pressure switch.
Check the drain hose height setting. If hose is not well placed you get water back inside the tub. Do a test with drain hose down in a bucket. Check the drain pump filter. Access filter housing and remove blockage if any. If front load machines he pump filter is accessed using a panel located at the bottom in front side of the appliance. With top loader you access the pump from underneath or from the back.
Check if the inlet valve or the hose is allowing water inside the appliance because of an internal leak. This will result in overflow being detected.
Check the pressure switch. This is the device that detects water level.
The pressure switch is near to the control panel . It is a round shaped plastic part that is connected to wires and to a long thin rubber hose going inside the tub. Clean the hose or replace the pressure switch.
Regards.
Ginko
Jun 14, 2011 | Washing Machines
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
