Question about Kipor Parallel Wiring Kit, 30 amp Twist Lock for IG2000P #66624
Is there a small approx 2000W gas generator with 48V output?
I am considering repowering my 24 foot sailboat with an electric inboard motor. In a bind I'd like to be able to run the motor directly off a small generator when the battery bank is low. The motor requires 24V DC.
  • 10,865 Answers
You need an inverter generator. checkout the honda line.
Posted on Apr 23, 2009
How reliable is patriot Power Generator?
Hello, are you looking for a diesel generator? Or you just want to know about generator related information?
When you choose a electrical diesel generator, you need to consider lots of factors. Read this article to get some suggestions. Important Factors Should be Considered When Purchasing Generator Set
Brand of diesel generator recommended, please visit this reliable website.
Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
Jun 18, 2017 | Miscellaneous
Generator will run, wont output electricity
You really didn't provide much info to work with - Knowing the make & model & size (as well as its age) would be helpful. Also is it new or have you had it for a while? What test equipment do you have? In other words, what are you using to determine if it is putting out electricity? Has it ever worked? All generators have individual circuit breakers, so try resetting those. If they trip-out immediately then disconnect the generator from the load. reset the circuit breaker(s) again & recheck the output some other way, such as by connecting a table lamp to it. If that works, then consider the possibility that your generator may be too small for the load that you're trying to connect to it. For example, a 2000 watt generator is good for a working load of 1000 watts but is too small for a 2000 watt load. If this is your first experience with a generator, check out the web site www.electricgenerators.com and refer to their sizing charts. Lots of good info there.
Mar 15, 2016 | Electrical Supplies
Where do i find parts
Nixon Power Services in TN can help you with a part
May 01, 2013 | Kohler Limited Edition Marine Generator 2...
The motor runs fine but will not generate any electricity
With the generator shut off.....
At the generator side of the generator we are looking for a small + and - sign on 2 connection terminals.......you may have to take a small cover off.
What we want to do is re magnetize the generator.
With a regular 9 volt battery.....or almost any small battery will do.....momentarily add the battery power to these terminals.....just for a sec......and thats it.......it's re magnetized.
Your generator will charge now.....if it was in need of a re magnetizing.
This is the cure for 70% of no output when running generators.
Sep 07, 2009 | Coleman Powermate Premium Plus 6250W...
10 kw deisel generator in sailboat suddenly stopped generating,
Are you still looking for help with your Gen. ?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jan 30, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Kipor Parallel Wiring Kit, 30 amp Twist Lock for IG2000P #66624 Logo
284 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
mark52001p
Level 1 Expert
Jay Finke
Jay Finke
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
