Question about HP Compaq nc6220 Notebook
I have 1.49g ram and need an upgrade to 2g
How to find the memory module sockets and replace it?
  • evad11544 Apr 23, 2009
    thanks for this. i've done it already
  • 741 Answers
The absolute best way is to go to www.crucial.com. The website will test your PC automatically and tell you exactly what you have and what kind of RAM you need. It will also offer the correct RAM for you on the same site, so you can do it all in one swoop..pls rate this solution. Once you receive the RAM, the Sticks are under the largest panel under your notebook. You can get the manual off of your manufacturers website to see exactly which screws to take out..but normall its under the largest plate..good luck..pls rate this solution
Posted on Apr 23, 2009
Constant beeps
this laptop can take 4G ram http://www.crucial.com/upgrade/Gateway-memory/M-1000+Series/M-1625-upgrades.html
if the memory modules are not from the same brand range, this can often be the issue.
it SHOULD be able to run with just 1 2G module but will run better with 2 1G rather than the single, assuming it's the right type for the machine.
If I'm upgrading pc memory, I remove the old and replace with Crucial or Kingston kits so as not to mix brands and ranges.
Apr 13, 2013 | Gateway M-1625 Notebook
Memory not working
The 2nd RAM module could be incompatible with the 1st RAM module or it maybe faulty.
Try using the same make and speed as the 1st RAM module.
Mar 10, 2013 | EliteGroup ECS A740GM-M Value Socket...
T6524 won't recognize all ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Feb 24, 2013 | eMachines T6524 PC Desktop
I just need to upgrade the memory on a Dell Precision 530MT.. can't seem to find the exact type of memory it needs.. any ideas?
HELLO Paul
When installing memory modules in the system board sockets and not using the optional memory riser boards, observe the following guidelines:
  • Each memory socket on the system board must be occupied either by a RIMM or a CRIMM.
  • Memory sockets must be upgraded in matched pairs. In other words, two sockets in a pair must contain modules of identical capacity, number of components, and speed. See "System Board Memory Components" to identify pairs of sockets.
  • Mixed pairs of ECC and non-ECC modules all function as non-ECC.
  • Be sure to install a RIMM in socket 1 first (closest to the processor) before installing modules in the other sockets.
  • The system board supports PC600 and PC800 memory modules.
  • http://www.memoryx.net/precwor530.html what memory part numbers you should buy and cost
the link below will give you what type of memory you need to isntall
http://support.dell.com/support/edocs/systems/ws530/en/sm/2memory.htm#1149832
please rate my service
Nov 19, 2010 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
My laptop HP Compaq 6510b Notebook PC . Can I upgrade the momary from 2G Ram To 4G of Ram ? . And the prosser Cor2Deu 2Gspeed Can I upgrade it to Cor I5 . Thank You
CPU upgrade is a big NO.
The core I5 is a different socket, and modern laptops use mobile CPU's.
Memory upgrade is ok, you can fit 4GB "Up to 4GB of 667-MHz DDR2 SDRAM, dual channel memory support "
Sep 03, 2010 | HP Compaq 6510b Notebook
My Dell Dimension 9150 is unstable. The Dell Diagnostic indicates memory failure in DIMM socket 3. I reversed the modules in the DIMM sockets and Dimm socket 3 failed again. Motherboard?? My motherboard...
Yes you can. Your best is to use the largest and best ram in the number one slot. I would remove ALL the ram and start with the 2 gig in the first slot - then add others until you get the error message - remove that one and keep the rest.
Mar 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Hi! How can I increase the RAM on my Aspire T310? Can I do it myself? Thanks.
Yes, you can definitely do this yourself. Upgrading RAM is one thing that repair places make much money; however, it takes a matter of seconds to complete.
Your Acer Aspire T310 has two memory slots on the motherboard. Each slot can hold a maximum of 1GB each for a total of 2GB RAM. You should see a great improvement in performance.
To save on a long tutorial, I have included a video link. The type of RAM you need can be found at the following link. Kingston is another manufacturer you could check into also.
Please remember to unplug all cords from your computer and be in a static free environment before upgrading your memory. Good Luck!
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=269237BDA5CA7304
Feb 26, 2010 | Acer Aspire T310 PC Desktop
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
Ram upgrade
Step 5: Remove a memory or continuity module Continuity modules do not contain memory, but are placeholders to close the memory circuit. Use the following steps to remove a memory or continuity module:
  1. Pull out, and then press down on the holding clips that retain the memory modules. The memory modules should rise up slightly out the socket. Figure 5: Opening memory module tabs c00571682.gif
  2. Pull out the memory or continuity module (for RIMMs) and place it in a static-safe container.
Step 6: Add a memory module Use the following steps to insert a memory module into an empty socket:
  1. If RIMMs are being used, keep the following items in mind when purchasing and installing modules:
    • The memory configuration of channel A (the first two sockets) and channel B (the second two sockets) must be identical.
    • Continuity RIMMs must fill any open memory sockets.
    • When a continuity RIMM is required, it should be installed into the second socket.
  2. Align the memory module so the small notches on the lower edge line up with the raised marks in the socket. Figure 6: Memory module installation c00571683.gif 1 - DIMM (notches farther apart) 2 - RIMM (notches close together)
Apr 11, 2008 | Computers & Internet
HP Compaq nc6220 Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
