Question about Dryers
Dryer will not start
Power to the dryer, I unplugged and let it sit, and plugged back in, no luck. when I press start, I can hear the mechanism trying to start.
    Problem Solver:
  • 10 Answers
Check to see if drum rotates by hand, might be stuck, if so see if you can see whats jamming it, after rotating try again
Posted on Apr 23, 2009
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
Dryer stopped in the middle of a cycle. Time kept going, drum and motor stopped. Unplugged dryer, check lint and exhaust hose for build up. Plugged dryer back in, when I select time and hit start, dryer...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Mar 12, 2011 | Bosch Nexxt 500 Dryer
Every so often my dryer will not start when you press the button you can hear the timer engage but the drum does not turn and the motor makes a sound like a car that wont turn over. I unplug it and let it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 21, 2010 | Maytag MDE2600 Electric Dryer
When selecting a dryer time, then pressing start,
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 26, 2010 | Frigidaire FER311FS Electric Dryer
Dryer won't start
Jon
Some dryers now come with a lot of electronics to run them and with electronics and heat, they don't like each other.
The click you hear is a relay switch on a board inside on or near a power board simular to a tiny computer,
Rplace that board.
Now to know which board is another question,
With the power removed (unplugged) disassemble the top part or the back of the dryer. When inside follow the main wires from the plug and see if it meets a electronic board. It could be or maybe burnt.That is you main power board, take it to an appliance shop to replace it
Take along your model# of your dryer
Happy drying
Jul 25, 2010 | Samsung DV306LGW Dryer
Screen says power failure occured during cycle press start/pause to resume cycle..nothing happens
sometimes if these machines are running during power failure they get lost in thee own programmin g
this particular machine is notorious for it
unplug the amchine and let it sit for a few minutes
plug it back in and you should be good t5o go
Oct 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
We had a power outage the other day, and now our Maytag MDE308DAYW dryer just buzzes when we try to start it. At first, I unplugged the power, let it sit a few minutes, and plugged the power back in, and...
Hi fixya. I solved the problem myself, it was pretty easy. I just unplugged the power; let it sit for a minute; plugged the power back in; then I opened the dryer door and while manually holding down the door switch, I manually spun the dryer drum and simultaneously my son hit the start switch - you need three hands to perform this procedure - and it started running! Then I let it run for at least an hour, and ever since that it has started perfectly well.
Oct 02, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer is not drying the clothes
I had the same problem that I just fixed. I removed the serial cable weeks ago. Unplugged and plugged cord to reset computer glitches. If this does not work. UNPLUG cord, remove the terminal block cover for cord connections. With a AC volt meter and plastic kitchen gloves, plug in, turn on dryer and check voltage. Red to Black 240+/- 6 volts. Those terminals to center 120+/- 3 volts. UNPLUG CORD if good voltage. With dryer de-energized you won't need kitchen gloves. Next take out 4 screws that hold Back-splash, lift and tilt forward. There is a wiring diagram inside. Plug and unplug each cord one at a time. Take care to not to bend prongs. My problem was a parallel cable that had a bad connection. Unplugging it and plugging it back in was all it took to fix the problem. Good Luck.
Mar 27, 2009 | GE Profile Harmony DPGT750EC Electric...
Whirpool LGR7646DQ0 dryer won't start -can hear timer running, timer stops when door switch is pushed, but dryer will not start.
there is a white fuse in back of machine.take back panel off and check for continuity to fuse.you can also put the two wires together and plug your machine in and make sure nothing is touching,and hit start button.UNPLUG FIRST.the fuse sits on blower housing.it will be white with a black strip down the middle and only two wires.
Mar 06, 2009 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
