Question about Kenmore Washing Machines
Screen (f-28) and keep flashing
I just buy Kenmore 46462 Front Load Washer and it stop working all light come on and its fine but when push buten to start 2 mints it showen in screen (f-28) and keep flashing.
thanks
mike
  • 530 Answers
Call for service this is a covered repair. you have something wrong with your motor or a loose connection somewhere. You say this is brand new if it is less than one year it should be 100 percent covered
Posted on Apr 23, 2009
Washer stops mid cycle and all lights flash and door is locked. no error code. We have to stop power off the washer turn power on and run through another full cycle
Reset the unit by unplugging for 40 minutes.
otherwise the ECU is at fault.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore 46462 Front Load Washer
The indicator lights that surrond the dial are flashing on my Kenmore 110.46462501 front loading washer.
Unplug and wait 40 minutes to reset the ECU and re-try.
Jan 14, 2009 | Kenmore 46462 Front Load Washer
F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Oct 13, 2008 | Kenmore 46462 Front Load Washer
Trouble with kenmore washer
I had the same problem. I called the repair center to have the problem looked into and fixed since it was under warranty for just a few more months. This is where I wish you all the luck and patience in the world. After 4 visits to my home over a period of nine weeks, and several attempts to order many parts that never fixed the problem, the tech finally figured out that the problem was with the door latch attachment and just needed an adjustment! I hope that this saves you about eight weeks and six days!
Sep 23, 2008 | Kenmore 46462 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
My washer won't get any water in and all lights are flashing.
possibly water inlet valve has failed this is the valve where the water supply hose screws onto on the back of the machine
Jun 11, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Kenmore front load washer he2plus
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Jan 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore 464642 Front Load Washer is causing towels and clothes to smell mildewy
just start with cleaning out the pump and the pipes that connect it both to the drum and the outlet, check the outlet on the wall that it is clear, given the info you have this sounds like that the pump is not clearing all the water in time and filing up with some old water left in the machine,, clear out these pipes with care and you should be fine, check the pump pushes out the water with sufficient force work safe unplug when working on appliances, electric and water don't mix hope i have helped, if so rate me please
Sep 19, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
