Question about Baby Lock Eclipse Serger
Baby Lock Protege BL5370Ed Serger
I am wanting to know if this model has a differential feed and approx when they were made. TY
  • samart123 Jul 07, 2008
    I have lost the manuel for my babylock protege and need the threading instructions. the lower threader keeps coming unthreaded. I have followed all the blue lines for threading and had the serger professionally cleaned.
I was in a similar position (but had the manual). The manual isn't as complete as I'd like. Anyway, what finally got mine working were the following:
1. turn all tensions to zero before putting thread through them
2. thread the upper looper, then lower looper, then needles.
3. when threading the lower looper (mine kept pulling out), after passing the thread through the looper eye, it needs to go pretty much straight up, not wrapping around anything else - other thread, for example. Mine was at one point trying to wrap itself around a post.
4.when everything is all threaded up, make sure all threads are under the foot *and* pulled to the left (even though the manual says pull to the back). Then chain off without fabric, turning the handwheel by hand to make sure loops are forming. If so, adjust tensions to where you think they should be (mine are currently all between 2 and 5), and add fabric. Then tweak as needed.
For me, this was a lot of trial & error, hair-pulling, and getting tips 1, 2, and 4. I figured out #3 on my own, with much swearing along the way. Good luck!
LF
Posted on Dec 31, 2008
I know it has a differential feed but don't know when it was made. just go to the Baby Lock website.
Posted on Sep 27, 2007
I have a baby lock protege and can't seem to get the stitching to look normal at all. TTOOOO many loops. Any ideas what I need to do?
JE
Posted on Feb 19, 2008
Baby lock serger will not feed, fabric want come out from under presser foot.
what is the stitch length set to? should be 2.5 or thereabouts for normal serging.
Is the pressure foot pressure turned up too high perhaps?
The reasons I could think of for it not feeding through would be:
- the feed dogs under the pressure foot are out of position/not moving
- that the differential feed is turned up so its pushing the fabric back to the front of the machine
- stitch length is set very low so hardly moving the fabric at all
- or youv'e got a thread tangle happening around the foot/blade area.
Jun 14, 2012 | Sewing Machines
I need an owners Manuel for a baby lock protege serger. Model number d6001990. I believe it is a bl432.
babylock manuals
go to the website
on the home page
go to downloads
click manuals
if they don't have what you need contact babylock customer service
Mar 11, 2012 | Baby Lock Sewing Machines
I have a baby lock protege and have had it for years with no problems. All of the sudden it is not making the loop stitch at all!, only straight stitching. What could be wrong, I have re-thread it several...
This is a timing issue and without the service manual and specialist gauges you will very likely break a looper in any attempt to DIY....the cost of a replacement looper is around the same as a service, so do it a favour and get it done properly....they will also give it a good thorough clean and lube.
Aug 30, 2009 | Baby Lock Eclipse Serger
Baby Lock Protege BL402 serger
try looking here for your answer, if you dont find one ASK the Baby lock people. :)
http://www.babylock.com/support/faq/?FAQ=10
Hope this helps!
Jan 11, 2009 | Baby Lock Ellure
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
What does the differential feed do?
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Mar 18, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
1,713 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
