Question about Vacuums
Vibrates very loudly when brush starts spinning
When I tilt the vaccum and the brush turns on it makes a loud vibrating noise, it also seems to be tearing up the belts, there is little black rubber "dust" all over inside, there is a tension bar that slides down onto the brush belt when the vaccum tilts back and it seems to be loose, any ideas?
    Problem Solver:
  • 10 Answers
Take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Posted on Apr 23, 2009
Changed belt on my eureka airspeed sweeper n since makes loud noise, really loud n vibrates
Sonja, Recheck belt installation, see if it is riding in proper groove or is twisted.
Press the helpful button and follow me on fixya for more tips and info.
Feb 11, 2016 | Eureka Vacuums
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Power brush makes noise on canister model
Make sure bearings spin freely. If brush roll is not cleaned frequently enough hair can damage bearings or end caps. f
Feb 12, 2014 | Riccar Vacuums
Loud eureka vacuum
A loud vacuum cleaner usually means you have broken the fan or impeller which causes it to be out of balance and vibrates
Sep 30, 2013 | Vacuums
Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
289 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
