Question about Valco Twin Runabout ATS Jogger
Front wheels swivel and get stuck on each other
Unless I have the front wheels locked, they end up swiveling all around and getting caught sideways facing each other. I don't really like to lock the wheels b/c then I have to tilt/lift the front of the stroller to turn. I tried locking just one wheel, but then there's a lot of friction with turns. In the reviews people go on about how easy this stroller is to steer. what am I missing?
  • ShanaBates Sep 08, 2008
    One of the front wheels of my twin runabout is much stiffer than the other and doesn't rotate as well which makes the stroller pull often to one side. Help!!
    New Friend:
I have the same problem too! Did you find a solution?
Posted on Mar 04, 2015
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
Posted on Mar 11, 2008
Is it possible to buy or adapt the rough terrain wheel for the bugaboo cameleon to swivel?
all bugaboo strollers came with swivel front wheels . There is a white sliding button on the front of the swivel assembly that locks the swivel action. The swivel castors are only on the front but can be assembled incorrectly on the rear of the stroller
go to google and type in base.bugaboo.com and there is a pdf manual for the strollers.including how to assemble and the wheels and castors.
Feb 10, 2015 | Bugaboo Baby Gear
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Quinny buzz front wheel just swivels.
Hi you can buy new & used very cheaply on ebay
Mar 11, 2010 | Quinny Buzz JUICE 2007 complete Brand...
My front wheel is sticking on my buzz. It gets
yes give it a good sqwert of WD40 and spin it round by hand till its free again it sounds like it may also be a bent shaft have you hit any big bumps? or has the baby put on a lot of wate?
Oct 24, 2009 | Quinny Buzz Three Wheel Stroller
Phil and teds sport stroller
melt some candle wax into the hole and put a drawing pin in it so its level and it spins easily without getting stuck
Jan 07, 2009 | Regal Lager Phil & Teds Sport Buggy Single...
Quinny Buzz front swivel wheel won't lock.
Make sure the wheel is central before trzing to lock it
Jan 06, 2009 | Quinny Buzz Jogger
My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
Hope this helps! Dan.
Nov 11, 2008 | Quinny Buzz Jogger
Hauk infinity reversible pushchair, swivel wheels won't swivel
Removed the wheels and gave a little spray of WD40 lubricant, the wheels swivel perfectly now - very easy!
Aug 29, 2008 | Hauck I'coo Pico 4 Standard Stroller
Front wheel getting stuck
i have the same problem, was wondering if you can buy the double one for the front. Have used wd40 on wheel and this has helped a little.
Jul 29, 2008 | Quinny Buzz Jogger
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
May 30, 2007 | Zooper Boogie Jogger Stroller
Valco Twin Runabout ATS Jogger Logo
331 people viewed this question
Top Valco Baby Gear Experts
Andrew Taylor
Andrew Taylor
Dorel UK
Dorel UK
Bill Boyd
Are you a Valco Baby Gear Expert? Answer questions, earn points and help others
