I have a philips 9p6044. where can I buy convergence ic's and a
HI.. My projection TV doesn't have a picture but has sound. I was told that it needed new convergence ic's and to rebuild the board. Help..
  • 8,617 Answers
Its far more likely that you need a new Vertical output IC. The convergence ICs wouldnt prevent the picture. When you have audio but no video it is often meaning vertical failure. Try replaceing the vertical IC
Posted on Apr 26, 2009
I have a philips 9p6044, and there is no picture or audio. It has power, but there is no display or sound. What can be the problem?
On that model if its making a constant chirp sound while powered on? If so then its most likely a convergence failure.
If its not chirping then the next most common failure is a power amp. Both are realtively easy DIY fixes. The website www.tvrepairkits.com has complete kits for both. Hope this helps.
Jan 28, 2013 | Philips Televison & Video
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 43P8341 will not turn on
sounds like your two convergence ICs are shorted out, plus you probably need two 6.8ohm resistors ICs are part # STK392-120
should be installed by a trained repairman cost about $300-400
Aug 17, 2009 | Philips 43P8341 43" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Tv comes on and shutts off immediately
he was checking to see if the set stayed on with the ICs out if it did the ICs are shorted. Its easier to unplug the convergence yokes and try it but some techs do it differently
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
Philips Magnavox 9p6040 c102
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Nov 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
