Question about Sharp UX P100 Plain Paper Thermal transfer Fax
Error code 25 26 what does this mean on sharp uxp100 fax machine
SOURCE:
leroyal
  • 2120 Answers
SOURCE: Error on Sharp fax UX-B700
Do you have a DSL or any kind of digital phone line?
Posted on Oct 26, 2008
slipnoman
  • 53 Answers
SOURCE: NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Posted on Jan 09, 2009
  • 48 Answers
SOURCE: sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
FixinFax
  • 3085 Answers
SOURCE: We are getting a 634 error code for a Sharp Fax
receiving machine is always BUSY
Posted on Jun 24, 2009
Help with Sharp Fax UXP100 . When sending a fax they are going very, very slow. What should I troubleshoot? Thx
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
hope my good deed free for the day helps.
cheers
Soulvisitor
Nov 22, 2011 | Sharp Office Equipment & Supplies
Sharp ar M451N F2 02
1.Improper cartridge(destination error,life cycle error)
2.Identification error
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Jul 14, 2009 | Sharp FO 4970 Fax
Com error
Two simple Solutions to the annoying COM.E-2 error problem on a Sharp FAX machine:
Get rid of your DIGITAL FAX line and go back to an old ANALOG phone line.
OR
Buy yourself a Canon, Rico, or Brother FAX machine.
(SHARP doesn't even have a list of their own error codes: Just like the place Dilbert works at, in the comic strip.)
This fix is Guaranteed to work.
Apr 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
Sharp MX350IN, error code 85-01. What does Error code 85-01 mean?
says toner is low, but doesn't specifiy which color is low
Dec 02, 2008 | Sharp Office Equipment & Supplies
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sharp UX P100 Plain Paper Thermal transfer Fax Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
