Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Electrolux dishwasher all lights blinking and wont turn on push start button either all lights flash or normal light stays on  either case the dishwasher wont run a cycle
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
  • Ted Walters
    Ted Walters Oct 22, 2013
    Electrolux are the worst dishwashers made.Period.All i get are Blinking Lights after spending 800.00 dollars on Two repairs.
  • John Broussard
    John Broussard Mar 26, 2014
    I removed the toe plate and the wash pump light was on but the unit was washing could the control think the wash pump is bad when it's not?
I had the same problem and followed rstecher and his solution. Removed the kick, light flashing was saying a leak was detected. Tipped the DW on it's side, have plenty of towels ready because the pan will be filled with water. Make sure power is off. Removed the pan and every single one of the clamps was loose. Tightened all the clamps at least 4 complete turns. Dried everything so the sensor wouldn't pick up any water. Put the pan back on and it worked perfectly! Thanks rstecher!
Posted on Jun 09, 2010
  • Jerry Alexie Dec 01, 2011
    I have done this twice and both times the dishwasher worked about 2 months, I have tightened everything I could get to, but it happened again. Can you jumper out the switch that is faulting?
I just tried the "tip and drip" solution suggested above and it worked. Thanks to all!
Posted on Jan 13, 2012
I have had the tech out here 4 time for the same problem ,all lights flash, This this is a cross between an albatross and a lemon, Im toast if they don't replace it im going to leave it on the front door of Lowes
Posted on Mar 31, 2013
I own a electrolux dishwasher mod no igot a service man out because wheni pressed the start button the lights would come on but when i took my finger off the button the lights would go out again the service man said it was a problem with the programe panel and did'nt recomend spending money on it too costly and too old. try this press the button down and tap something down along side the button to hold it down i used a panel pin now bend the pin across the button and put tape over it to avoid cutting your finger if the lights now stay on select your programe and close the door if it works then it was only the start button that was at fault when the wash ends turn the machine off at the socket untill you need it again next time turn machine on at the socket and repeat what have you to loose good luck jim maguire kells co meath
Posted on Feb 13, 2011
Normal wash light is blinking but, won't start
Hello friend, thank you for your post!
From the information you have provided regarding the heated dry and washing lights blinking on your Electrolux dishwasher it sounds like it could be a possible problem within your control board. I would recommend resetting your appliance which you can by flipping the household circuit breaker in the off position for roughly ten minutes. If you continue to receive the blinking lights I would reach out to a professional to come and diagnose your appliance. I hope this helps. -Matt
Aug 12, 2014 | Electrolux Dishwashers
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
11,891 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
