Question about Dryers
When I hold in the push to start button on my Maytag dryer it works, but when I let go it stops.
  • Anonymous Apr 23, 2009
    No hesitation.
  • 530 Answers
Does it hesitate while you are pressing the start button? you can either have a bad motor or the push to start button could be bad.
Posted on Apr 23, 2009
  • erica graber Apr 24, 2009
    pretty sure that it is your start button some of them have solinoids in them and if the solinoid isn't working that will happen.
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
When i push the start button the dryer buzzes like it wants to turn on but does not start turning. then it stops buzzing when i release the start button.
SOUNDS LIKE A MOTOR WINDING. GRAB A HELPER TO PUSH TO BUTTON WHILE YOU HOLD THE DOOR SWICH IN AND TURN THE DRUM SEE IF IT STARTS THEN. YOU MAY NEED A MOTOR.
Mar 03, 2010 | Maytag Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytage MDE3080DAYW
Hi, it sounds like you have a bad motor. You can try and open the door, hold the door button while having someone push the start button. Try turning the drum with your hand while these buttons are pushed and see if the dryer starts. It sounds like the start winding has gone bad.
If the drum will not turn, remove the front panel of the dryer and see if something has gotten into the blower wheel to stop it.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 13, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Maytag dryer will not start completely.
replace motor it would hold a load and is kicking out on over load switch
Dec 08, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
