Question about SanDisk Sansa e200 MP3 Player
Sound Only Comes Out Of The Right Earphone
The sound only comes out of the right earphone when I plug it into the jack all the way. If I pull the earphones part way from the jack I can hear sound in both earphones. I have already tried a new set of earphones and had the same problem
  • 626 Answers
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Sep 24, 2007
  • Super Dragon
    Super Dragon May 10, 2014
    How can I fix it on my own?
Sound does not transfer from laptop to earphones when they are plugged in. Tested earphone and test was good. How do I get the sound to come out of the earphones instead of laptop?
I would guess there is a fault with with the earphone jack socket, the soldering to the printed circuit board or perhaps some of the electronic components that might or might not provide attenuation and/or tone correction for the earphones.
Probably be a cheaper cure to use bluetooth.
I use a usb FM transmitter so my sound files can be played on any nearby FM radio.
Dec 03, 2015 | Compaq Computers & Internet
How can I fix a walkie that can not receive sound messages?
Check if it has an earphone jack if it does try plugging an earphone into it If you have audio through the earphone jack then the switch in the earphone jack could be bad or the speaker could be open this would be an easy repair. You might have a broken wire to the speaker. other causes could include cold solder joints bad volume control, bad audio amp, bad transmit receive switch etc
Aug 07, 2014 | Cobra microTALK LI5600-2dx Two Way Radio
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
Left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
May 03, 2010 | Philips Audio Players & Recorders
Sound comes only in one earphone..
your headphones probably blew in the one ear. Try another pair of headphones.the same thing happened to me. if that doesnt work the recepters in the ear jack youll have to have a professional to fix it
Feb 28, 2010 | Philips Audio Players & Recorders
Only my right speaker works and the sub
I worked it out. I was having the same problem. you probably have the GREEN EARPHONE JACK plugged into the GREEN INPUT PORT on the side of the xrocker? simply move the GREEN EARPHONE JACK to the BLUE OUTPUT JACK on the xrocker and your sorted :) it was really bugging me so i messed about until i sorted it :)
Sep 20, 2009 | Pyramat Sound Rocker Gaming Chair
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SanDisk Sansa e200 MP3 Player Logo
153 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
