Question about Sharp EL-531VB Calculator
Sigma to the power of
How do I do this on the calculator?
  • Sharp Master
  • 8,068 Answers
You must first enter the data you are doing statistics on.
After you finish entering the data, do as the figure below describes.
Hope it helps.
Posted on Sep 20, 2009
How to do sigma notation?
The calculator cannot add the terms of a sequence. You need a graphing calculator that has that feature, or a calculator with a CAS (Computer Algebra System).
Aug 10, 2014 | Casio FX-270W Calculator
Sigma notation on fx9750gii
The syntax is
Sigma ( function (n),index n, starting value of index n, ending value of index n, increment of n).
If you omit the increment of the index the calculator will assume it is equal to 1
Dec 02, 2012 | Casio FX9750GII Graphic Calculator
Where is the standard deviation button?
There isn't one. Press the "STAT VAR" button to bring up the statistics menu. "Sx" and "Sy" will give you the sample standard deviations, while "sigma x" and "sigma y" will give you the population standard deviations.
When I say "sigma" I mean the lower case Greek letter sigma, which looks like a lower-case "o" with a tail pointing to the right.
May 19, 2011 | Texas Instruments TI-30 XIIS Calculator
Hello. I just wanted to ask you how do I calculate the variance and standard deviation in my cfx9850GB plus. I had a quick look at the manual but I couldnt find the info. thankz .
This shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the statistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Example: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Sep 05, 2010 | Casio CFX-9850G Plus Calculator
How do you find standard deviation on the calculator?
Press 2nd [CSR] (shift-7) to clear the statistical registers. Use the Sigma+ key (just above STO) to enter data points. Use 2nd [Sigma-] to remove erroneous data points. Use 2nd [sigma x n] (shift-divide) to compute the population standard deviation, or 2nd [sigma x n-1] (just to the left of the previous key) to compute the sample standard deviation.
Jun 07, 2010 | Texas Instruments TI-30XA Calculator
How do I use the standard deviation function?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Apr 30, 2010 | Casio FX-260 Calculator
How to use that standard deviation on the Casio fx-260solar calculator
Apr 27, 2010 | Casio FX-260 Calculator
How do you calculate standard deviation?
Jan 26, 2010 | Casio FX-260 Calculator
How do you do a linear regression graph on a casio graphing calculator?
I am aware that the solution provided below is valid for the CFX/FX-9850G/GB/ but I will supply it. I remain convinced it will help you for your calculator.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
Hope it helps.
Oct 04, 2009 | Casio FX-9860G Graphic Calculator
Standard Deviation
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
maxX=90
Mod=90
Hope it helps.
Mar 09, 2009 | Casio CFX-9850G Plus Calculator
Sharp EL-531VB Calculator Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
