Question about Woods Industries 59377 Indoor Digital Timer 7-day
I want to reset but I lost the manual.
My woods timer model 1600 needs to be reset but I lost the manual. Could you show me the procedure.
    President:
  • 2,692 Answers
Here is the link to the directions :
http://www.woods.com/timers.asp
Posted on Apr 23, 2009
How to program model E257484
This model number does not show valid search results.
Following link has manuals for many outdoor timers;
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 17, 2014 | Hardware & Accessories
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Lost instruction for Westek Timer TE02
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
2) Model number and timers change frequently.
If your timer does not show, then add a photo or comment with clear description of timer
Dec 06, 2012 | Hardware & Accessories
Lost manual and i need to reset the timer
You posted under Woods 59028 almond-colored 7-day in-wall timer
Woods timer usually has Woods printed on it
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
If this is not your timer, add a comment with more information
Also look at timers on following pages to help identify your timer
Most of these timers have similar programming, except with slightly different buttons, and some offer daylight savings time, and dawn-dusk feature
http://waterheatertimer.org/Programmable.html#Aube
Dec 12, 2010 | Woods 59028 Programmable Timer Switch...
I have lost the instructions how to set a noma 7 day timer model N1507
Link show all Woods timers and manuals.
Noma is one name used to market Woods timers
Woods N1507 is also 49565
Woods N1507 manual
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment if this manual does not match your timer.
Dec 06, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Woods timer model E192912
I do not recognize E192912 number
You posted under photo that shows Woods 59377, which is also sometimes Utilitec 155671or 95363 or TE06WHBL or Woods 49377 or TD2200.
Woods timers have different model numbers for same timer depending on who packaged and sold timer.
Look through page below that shows photos of Woods timers plus manuals, and then add a comment
Dec 05, 2010 | Woods Industries 59377 Indoor Digital...
Woods model 16ULD/3A timer-lost instuctions
I have not heard of Woods 16ULD.
Woods timers sometimes have more than 1 model number for same timer, depending on who packaged and sold timer.
You posted under Woods plug-in timer with segments around edge of dial.
If this is not your timer, add a comment.
Also see lost of Woods timers where you might recognized photo of your model:
To program Woods timers with segments:
Rotate dial until current time lines up with arrowhead located on inner dial
Segments around outer edge of dial lift up.
Use fingernail, or small screwdriver to lift up segments when you want timer to turn OFF.
Leave segments down for times you want timer ON.
Slide switch located on top of timer is manual override.
Move switch to ON position when you want lights ON full time.
Move switch other direction for timer program to operate.
Timer dial rotates with passing time.
Program repeats each 24 hours.
Table lamp must be turned ON for timer to function.
If timer doesn't work, check receptacle for power, check that lamp is turned ON, and check that bulb is good.
Nov 30, 2010 | Coleman Cable Woods 59366 Lamp and...
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Feb 02, 2009 | Woods Industries 59377 Indoor Digital...
Woods Industries 59377 Indoor Digital Timer 7-day Logo
557 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
