Question about Gateway 2520915 Keyboard
Keyboard "key" problem shifting cursor to another part of text
Gateway M675 laptop XP 2002 Prof SP3
Appears that when typing text when hitting the "th" such as in the word, "the," the cursor "jumps" to a previous spot on the page. Also when hitting just the "t" itself.
My touch pad is "active" but I use a Kensington Trackball Mouse. Can't seem to be able to de-activate the touchpad.
  • Bert Canepa
    Bert Canepa Apr 26, 2009
    First, thank you for you prompt reply.
    Did, "Start, Control Panel, Mouse" comes up with the Kensington Orbital Properties; no tab relegated to "Touch Pad." So, was unable to follow thru on that suggestion.
    Checked regional language options and they "appear" to be ok...everything "English." (Date, time, ok)
    A bit of background:
    My hard drive failed about month ago; had new hard drive installed; Have had problems since with "locating touch pad" enable/disable (which I was always able to access before on "old hard drive."
    Had Windows XP Home Edition on previous drive.
    New drive have XP Prof SP3.
    Since as stated above have not been able to access "touch pad" in Control Panel.
    The keyboard prob started about month after new installations.
    Have now discovered that the top line of keys on keyboard, "Esc, F1, F2 etc thru Del...are inoperative.
    This is very frustrating as I'm a writer and I depend on Word......heavily........
    Appreciate any further advice before bringing to IT people.......
  • Bert Canepa
    Bert Canepa May 13, 2009
    My problem with the keyboard and the "....unable to de-activate the touch pad" has seemingly been solved by my daughter's "tekkie" on site at their copier company (at no cost) in San Jose, CA.
    This is for your information:
    The touch pad software had to be reinstalled; touchpad is now inactive and my "external" mouse is working fine (I now have a Kensington Roller Ball Mouse)...
    Recently I downloaded "Driver Detective" which the Tekkie took out of the system...he said that that kind of software inevitably cause "conflicts" within the operating system and should not be used.
    So my keyboard and my touchpad problem has been solved.
    I thought it would be wise to pass on this information and how it was done.
    ignazthecat (somewhere in the Sierras)
  • 385 Answers
On XP systems: Start/Settings/Control Panel. Once the control panel opens up, double click on "Mouse". In Mouse Properties, click on the tab at the top called "Touch Pad".
There should be a little box called "Tapping". Uncheck that. All the other options below that should grey out. You have just disabled the ability to select something by tapping on it. You can still move the mouse around, but you would have to press on one of the touch pad buttons to highlight and select any object. If you want to turn it back on one day, simply check that box again.
OR....
There is also a section on the bottom of that touch pad screen that's labeled "Typing". Make sure that there is a check mark beside the field "Tap off when typing". That means that when you are typing something, if you accidentally smack the touch pad with your hand, it won't be active. You can also set how long of a wait after the last key was typed before the pad is active again.
Also run a virus scan, Jumping around is not normal behaviour,
Also check regional language options in the control panel are set for the correct language,
Keyboard errors are associated with your region options.
Hope this helps
Regards
Richard.
Posted on Apr 26, 2009
  • Richard Finney
    Richard Finney Apr 26, 2009
    Half of the Keyboard in-operative, strange is that.
    Try running a virus scan, if this turns up nothing.
    And your regional languages are set correctly.
    Your having a keyboard malfunction there.
    Function keys are not really the usual keys to go first either,
    usually the ones you use the most tend to go first.
    Also could depend on the age of the system too. age is a factor, if used heavily.
    Richard.
  • Richard Finney
    The way to confirm keyboard problems, is to plug an old USB keyboard in, if this functions ok.
    You have just confirmed the keyboard is defective on your system.
    Regards
    Richard.
Cursor jumping around while typing text
You wouldn't have some live insect in your keyboard have you? I've seen Microwaves do strange stuff when infested with some tiny insects BUT I doubt it's the case with your machine. I am trying to recall a Keyboard key that I sometimes accidentally press when trying to create a document using Word, etc which does the same or similar to what you've described. It pees me of as I don't know which button I hit, it is one of the main reasons I avoid Word, Outlook, etc. Please let us know if solved, cheers.
May 02, 2013 | Computers & Internet
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
Inadvertant deleting of text
Your description is not very specific, but I can provide one possibility that might be the cause of your problem.
Your keyboard has an "Insert" key. If you accidentally hit this key , and then position your cursor in the middle of some text, anything you type will write over all of the text ahead of it.
If this is what you are experiencing, you need to tap the insert key a second time to turn it off.
Oct 20, 2012 | HP Pavilion dv7-1130us laptop
The lower caSe S on my keyboard doeS not work. I have inStalled a new keyboard but Still have the Same problem
Check in your control panel and make all changes back to default :S or do in this way which I had similar problem except would not type capital letter "A" when you hit shift+A. My kids were playing with my laptop and had been playing with Speech function. System Preferences>System>Speech> Text to Speech; de-selected "Speak selected text when the key is pressed". Works fine now.
Ford F150 Body Kits
Jun 07, 2012 | Microsoft Windows XP Home Edition English...
On my laptop, the cursor jumps unpredictably to previously entered text.
The space bar 'contacts', internally are dirty or defective. You will probably need to replace the keyboard or seek from manufacturer a 'cleaning process ' for this keyboard.
Mar 03, 2012 | Computers & Internet
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
I have A Packard Bell Easy Note R 9250 model MIT-RHEA-S P.N. PB23D00206 S.n. 493900380233 OS Windows XP Professional SP3 It happens more and more frequently that during typing text the cursor move...
win xp is no longer supported by microsoft so there could be a problem in the operating system
you may be able to get to the control panel/settings and see if there is a keyboard section in properties that you can check compatibility or drivers
May 26, 2017 | Compaq Keyboard
How do i access the @ on the key when i do shift and the key it will not type @
Hold down the Shift key by using your one finger and by using the other finger hit number 2 or @ key together. It must type letter @.
May 18, 2010 | Gateway Laptop Keyboard for MX6930,...
Keyboard `problem `strange `dash `appearing
Many programs extend the usefulness of the function keys by using key combinations. The most common combinations are Shift + a function key, Alt + a function key, and Crtl + a function key. These combinations can be very useful. For instance, in Microsoft Word, when any text is highlighted, pressing the Shift key plus the F3 key will change the case of the text from all caps, initial caps, to all lowercase. Shift + F7 will choose the Thesaurus command. These shortcuts allow you to access such functions with one keystroke rather than three or four mouse clicks.
Dec 23, 2008 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
