Question about Kenmore 34722 Grab-N-Go Upright Vacuum
I have a kenmore grab n go bagless and I need to know the exact size of the belt, I lost the manual, and I have burn several belts at the bigining of the problem the motor stops and burn the belts I open it and I think it was a little piece of plastic, that cause the problem, but when I put the new belt it looks like the motor works fine,but still burn the belt, I`m using UB-1 #5275 belt am I using the wrong one?
  • Anonymous May 07, 2009
    This looks to be it. I'm gonna order and see. Didn't find the model at Sears or Amazon...
  • 1,162 Answers
Here is a link to kennmore vacuum
it says online the model number you gave is the correct one.
Posted on Jul 23, 2017
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
  • 1214 Answers
SOURCE: Vacuum has lost suction
Check the throat of the vacuum head where the air is sucked to the filter box. Check that it is not clogged.
Posted on Jan 23, 2009
SOURCE: Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Posted on Jul 26, 2009
SOURCE: Need to replace belt in Kenmore Vacuum Power-mate nozzle
I have power and all .. but the vacuum leaves behind dirt after shutting it off. do you think the brush needs to be replaced maybe along with the belt. belt maybe slipping?
Posted on Apr 21, 2010
SOURCE: Kenmore Model 116 PowerMate Jr stopped working
SJ, I jumped the fuse and all is working as you suggested. I see Radio Shack has 3 temp fuses available. Which one did you use. Thanks for the help.
Posted on Apr 30, 2010
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
The vacuum went its on and running a faint burn smell
That means that you need to change the belt. Here is the belt you need and the manual which has instructions:
Eureka 2961AVZ Belts
Owner's Manual
Jan 03, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 431BX Bagless Upright Vacuum: i would like to know how to replace and if there is a specific type of belt to use?
Here is a link to the exact belt you need to replace (the belt should be replaced yearly for optimum performance) and a manual you can view which has instructions.
Eureka 431BX Replacement Belt
Owner's Guide (1.1 MB download)
Dec 07, 2009 | Eureka 431BX Bagless Upright Vacuum
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Eureka 2981bvz bagless belt pully is getting too hot and burning through belt
Check the brush roll, if one end has overheated and is locked up so it won't turn, then you need to replace the brush roll.
Jun 04, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Kenmore 34722 Grab-N-Go Upright Vacuum Logo
423 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
