Question about Canon CanoScan 8400F Flatbed Scanner
Yellow streak through color image scan
When I scan color, it doesn't matter where I position the item to scan, I get a yellow streak through the scan. The streak is so bad that I can even adjust or tone it out of my photo. The scanner is an Epson Perfection 3490 Photo scanner, only 2 years old. It used to work great. Can you tell me what is wrong and how to approach fixing it? Thanks so much.
Crysti Esper I've been using the CanoScan 8400F for a few years with no problems.  Suddenly I started getting a yellow streak down the right side of the page on all color scans.  It seems to be getting larger.  I've emailed Cannon, but so far to no avail When scanning a color picture the image has a yellow streak covering about 25 % of the image. This problem did not occur when the scanner was new
    Novelist:
  • 133 Answers
There might be many causes of lines on the image.. Depending on weather the line is Horizontal (Parallel to the scan lamp) or Vertical (In the direction of the motion of the lamp).
Vertical lines are due to certain CCD cells not responding properly, and that "bad spot" is moved down the page by the carriage motor, making streaks. The problem can be due to dust inside the scanner, on the CCD or mirrors, blocking light from reaching the CCD, and these tend to be dark lines (perhaps dark in only one of the RGB channels) and relatively few in number. The problem can be defective electronics in the scanner, and these lines often appear as red, green or blue lines (stuck on), and sometimes in great numbers or width. However, a deposited film on the mirrors can be wide and colorful too. Vertical lines tend to always be at the same place on the width of the scanner bed, being caused by specific CCD cells
Horizontal lines are an event in time. Rainbow colored lines might be due to a flickering lamp Or the scanner has an internal high frequency power supply for the lamp which might cause such a problem. A faulty or incorrect or insufficient power cube may be the problem. Is the problem everywhere, or random locations, or always in one place in the carriage travel? It could be irregular movement of the carriage due to loose belts or sticky guide rods or other mechanical interference can cause "glitches". You might notice the lamp flickering, or watching the carriage carefully while it moves might show some type of binding. Horizontal lines due to lamp problems are random, showing at whatever location of the carriage at that point in time, but a sticky carriage would probably always be seen at the same location. Effects of an insufficient power cube is probably seen all over the image.
Hope this would help you to pin point what might be the problem.
Let me know if that helps and rate the solution if you liked it.
Thanks and Regards,
Srinivas
Posted on Apr 23, 2009
2 Suggested Answers
SOURCE: Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Posted on Aug 05, 2009
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Streaks of color when scanning film
you need to clean of reflection glasses of lens so if you are handy on it then take off fron scanning glass and take out glasses and clean the out with clean cloths.
and put them back.
note: if you are not aware of it please do not mess up with them because it will be more annoying.
good luck
please rate all answers.
Apr 06, 2009 | Epson Perfection 4490 Film / Flatbed...
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
I think your flatbed lamp is damage
if u replace or color it pure white ink
Jun 10, 2008 | Office Equipment & Supplies
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Oct 23, 2007 | Xerox Phaser 7700 Laser Printer
Canon CanoScan 8400F Flatbed Scanner Logo
527 people viewed this question
old marine
old marine
