Question about Yamaha RX-V793
The reciever turns off suddenly while watching a movie on dvd
Whenever I am watching a movie on dvd,the unit turns off automatically and there is no sound.I have to keep turning it on again after it shuts off.No problem while watching tv though.
  • 752 Answers
SOURCE: Power loss
Its possible that one of the speakers wires are shorting out or touching the case of the unit (leads to protective shutdown).
Posted on Sep 15, 2007
  • 979 Answers
SOURCE: losing digital picture with HD TV
First, hide the remotes so that the TV cannot "see" it. If the problem goes away, it's the remote. Other than that, it sounds as if the receiver is faulty...accordianman
Posted on Nov 05, 2008
  • 1114 Answers
SOURCE: Yamaha Receiver sound cuts out with Dolby Digital.
Your problem is related to HDMI technology not the Receiver. HDMI in it's current version 1.3b has worked out 90% of the current problems being reported by HDMI users. it's a problem with HDCP digital copyright protection and the recording industry not wanting us "consumers" to duplicate or record their DVD's. Your receiver and every other receiver with version 1.1,-1.2, & 1.2a just don't cooperate with BluRay and even HD Cable or HD Sat receivers. If you just purchased this receiver recently, return it and get an 09' model or equivalent with 1.3a or 1.3b HDMI technology. If this unit is "un-returnable" then, what needs to happen is you need to run component video and digital audio to the receiver OR Run your HDMI directly to your TV and run a Digital Coaxial to your DVD audio input on the receiver. Depending on how many sources you are running to the TV via HDMI will be limited to the TV's capability (how many HDMI inputs)
Now, if your TV is 50" or smaller, the difference between running HDMI and Component is unmeasurable to the human eye. So, if you have to run component, don't sweat it! just use good cable, ie. Monster, Phoenix, Translucent etc. I do theese installs every day, and I still prefer Component or DVI if available over HDMI. They just haven't proved the reliability to me yet and we're three years in! Hope this helps
Posted on Jun 23, 2009
  • 1810 Answers
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Posted on Jul 25, 2009
  • 227 Answers
SOURCE: humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Posted on Sep 13, 2009
  • 101 Answers
SOURCE: while watching a movie the reciever shuts itself
Please note exactly after howmany minutes.
If you cannot determine the exaxt time the reciever switchoff.
may be any component on the mother board gets heated up or dry soldered.
try to solder the component.
Posted on Jan 10, 2010
0 characters
1 Points
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio & Video Receivers
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Power cuts off periodicly
Maybe. Try a larger guage extension cord.
Jun 11, 2009 | Sony STR-DG820 Receiver
Can't get Surround Sound with Movie
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
My NAD T763 turns on but no sound comes out of any speakers
I had the same problem and AH reset did not work. IS there anything else i can do?
Dec 02, 2008 | NAD T763 Receiver
Denon AVR-1906 Reciever is not working. Was watching a movie and then it suddenly shut off. Now, the power light is blinking red. When I try to power it on again it starts to boot up but then turns off...
speaker terminal are short circuit,switch power off connect speaker properly then switch power back.
-the ventilation holes of the set are blocked-turn power off and make good ventilation around leave the set to cool and turn power back.
-the unit is operating at continuous high power turn it of and allow for cool down and switch it back.
Jun 01, 2008 | Denon Audio & Video Receivers
Clicking sounds
i had this condition on another denon a/v receiver it started clicking got worse as time went on progressed to snaping sound more so when switching modes ie dvd to tv etc then l/frt speaker would cut out found by gently tapping l/side of the chassis it would pop & snap sent it out to denon & they replaced the dsp unit no problem since hope this helps Alan
May 22, 2007 | Denon AVR-4306 Receiver
"Protect" feature increasingly activated.
You may have an output transistor gone bad and it is trying to run on one good transistor since they commonly are used in pairs (one positive and one negative). Time for a trip to the shop. Good luck.
Jan 23, 2007 | Sony STR-DE585 Receiver
Yamaha RX-V793 Logo
53 people viewed this question
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
