Question about GE Profile Prodigy DPSR513GA Dryer
No heat I turn my dryer on and I get no heat no matter what setting i put it on
    Problem Solver:
  • 10 Answers
Make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Posted on Apr 23, 2009
My dryer runs about 30 minutes and then will shut off. After you give it a minute to it will turn back on but when it is in constant use it happens very frequently. It doesn't matter what heat setting it...
sounds like the safety thermostat (Hi Limit Thermostat) is cutting your dryer off. This usually happens because of hi heat (higher than normal) which is caused by clogged exaust.
Check your dryer vent to ensure that is is completly free of lint. Clean the lint from the lint trap all the way to the output of the exaust outside your dwelling, ensuring the dryer has a unobstructed flow of hot air.
R/Jim
Feb 16, 2011 | GE DBXR463EDWW Electric Dryer
I own a Maytag Atlantic that is only blowing cold air no matter what cycle I set it in also when I open the door the light is not turning on, could this be related and what the causes may be?
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
My Kenmore dryer seems to have a mind of it's own on heating. Sometimes it heats very hot, sometimes little heat at all. It does not seem to matter what setting it is on, low, med, or high. Nor does it...
when was the last time you cleaned it out,try running it with the vent line removed,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac put it on blow and blow off the motor and clean out the vent line and the outside vent,if the vent line is long i use a leaf blower to clean out the vent line,also is it gas or electric?next time send model number?if it's gas you could have bad gas coils,when they heat up they fail,clothes are warm at end of cycle.run the dryer for 15 to 30 minutes and check to see if the flame is still lighting if not bad gas coils.hope this helps
Feb 21, 2010 | Kenmore Dryers
We moved the dryer and tilted it to adjust the feet to make it level. now it puts out very little heat. doesn't matter what heat setting it is on - the same small amount of heat. any suggestions?
It sounds like you have crimped the vent pipe and partially blocked the flow. Pull the dryer out from the wall, unhook the vent pipe and check to be sure you don't have a partial blockage of lint or maybe a kink in the pipe. Regards, Joe
Jan 13, 2010 | Whirlpool LGR7646E Dryer
Dryer runs and heats but shuts off prematurely
It could be the timer or the sensor as well. Before replacing parts, it may just need a cleaning. If you are not familiar with the product then you should call a professional. The dryer is designed to shutoff when it is overheating, which as you stated it heats up nicely, but shuts off.
Lint, the unfortunate result of drying gets on the sensors and other parts and causes them to react prematurely. If you haven't cleaned the unit, it may just need that, if not I would then say start looking at replacing parts. For safety concerns, you should have your dryer cleaned yearly.
Another thing to check is the exaust for kinks or blockage, when this happens it causes heat back into the unit and again shuts it down.
Give those a try and it may just solve your problem.
Thanks,
Paul
My Website
Jan 28, 2009 | Kenmore 63942 Dryer
NO HEAT from lg 2515s dryer
your heating element is burned out.
Dec 08, 2008 | LG DLE2514 Electric Dryer
Kenmore Thermostat
hi,
order or study the wiring diagram, could be a hi/lo heat setting circuit, the dryer should spin no matter what heat problem, jump the door switch
J
Jul 11, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
213 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
