Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Flashing Red Light
About every other time I turn on my camera, the red light next to the viewfinder flashes and the camera won't respond. The problem is resolved if i turn the camera off and back on again, and it then works fine. Like I said, it seems strangely regular--every other time I turn on the camera. Any ideas?
  • lytical Mar 06, 2008
    In low lighting, my Exilim 8.1 won't take a picture if I have the auto flash setting on.  The red light on the back of the camera continually flashes, like it's busy.  When I try to take the picture, nothing happens.  The only way I can get the picture to take is to turn the flash off... and then, it's blurry, due to low lighting.  It didn't do this when I first got it, and I don't know what's different now. I've tried recharging, removing then reinstalling the battery, changing memory cards... nothing I've found works... except to turn the flash off, and take blurry pictures.  Any suggestions?  Did I change some setting without realizing it?
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
SOURCE:
When I try to take a pic, the camera beeps and a red light flashes.
Hi. Based on your brief description of the problem I would think that the camera is failing to focus and the flashing red light in the viewfinder is the auto-focus indicator, make sure that the red auto-focus indicator is positioned in the centre of the viewfinder initially until you have experience of using it (to do this consult your camera manual) focus on a subject that has some contrast ie a red brick wall, grass or pebbles on a beach.
Apr 15, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Daughter opened battery area under water accidentally. dried it. red light at battery flashing. Can it be fixed??
The good news is, the flashing red light on your camera means that the camera itself did not short-circuit and still may work. If it's flashing red next to a battery logo or it is a flashing battery logo that could indicate that the battery itself is fried and you would need to purchase a new battery. You can find camera batteries for cheap on websites such as Amazon.com
Oct 19, 2012 | Nikon COOLPIX Cameras
I have a panasonic th-42pz800a and it wont turn on all that appears is a flashing red light instead of the solid green light next to the button on the tv... any helpers
Flashing red light is an error code, please count how many times red light is flashing after long pause and let me know to diagnose possible cause of problem..
Thanks.
Mar 18, 2011 | Panasonic Televison & Video
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
Red flashing indicator in viewfinder of my Canon XL1E
Hi . .  I downloaded the manual . . found I needed to replace the 3 volt lithium battery located on the underside of the hand grip for the zoom. Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
Feb 28, 2009 | Canon XL1E Mini DV Digital Camcorder
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
1991 CANON CANOVISION E100 / E110 Red light flashing after 2 minutes, not condensation, battery well charged. No picture appears in viewfinder when red light is OK & not flashing. HELP!!!
ive gt to use it recently and it woot the canovision E100,hardly been used i went to use it and it wouldnt come on , there is a red light
Aug 19, 2008 | Canon Cameras
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
76 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
