Question about Maytag Neptune MDE5500AY Electric Dryer
Motor kicks out
I have a maytag dryer model # mde5500ayq. It will start up and run until I shut off when I try to restart it the motor kicks out.
  • pnslopez Apr 23, 2009
    Motor was replaced and new motor does the same exact thing
  • 530 Answers
Sounds like you have a bad motor
Posted on Apr 23, 2009
Dryer hums but will not start
bad motor,if it does start and runs then shuts down and you can't restart it until it cools down you have a bad motor,or open the door and see if you can spin the drum,i found a dryer that the belt cut through the pastic belt pulley and the motor couldn't turn,also something could be stuck inthe blower wheel but if you can spin the drum then it's the motor.the noise you heard is either a bad roller,the belt pulley or the motor bearing.next time send the model number and i can look up you dryer to see what parts are in it.hope this helps.
Dec 29, 2013 | Maytag Dryers
Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Dec 12, 2007 | Dryers
Hello I have a MAYTAG NEPTUNE DRYER Model# MD5500 (MDE5500AYQ) . The console panel lights up.You can load up a cycle on the display but the unit won't start. It Just beeps or locks up.So I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer would run half cycle until it would shut down. now it struggles to start and then stops. pyg2300aww model.
Good day,
Every indication the motor is failing. Not uncommon.
Could be a bearing dragging badly, or idler assembly bearings, doing the same thing, but
A complete tear down of the dryer would need to be done to verify the problem.
Once again,figure the motor as the problem.
Thank you for using FixYa
Dec 25, 2009 | Maytag Dryers
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
Maytag gas dryer, model #MDG7600AWW does not turn on
a thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Sep 12, 2009 | Maytag Dryers
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag neptune dryer mde5500ayq replaced old motor with new motor starts up first time alright I turn off and it will hesitate to restart. most times it will not restart. Humms then kicks out. I have no...
Compare the wiring connections on both motors. They may be marked. They may be different. Careful examination will determine the start and run wires. Other wires turn on the heat once the motor reaches running speed. The thermal fuse for the motor is internal and unservicable. The hi limit sensor will control the heat, but will not necessarily turn off the motor.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer quit running
your motor could be going bad. after running for several loads the dryer motor may be overheating and shutting down. wait for a while and if it restarts, replace the motor
Mar 30, 2009 | Dryers
Maytag dryer will not start completely.
replace motor it would hold a load and is kicking out on over load switch
Dec 08, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
