How do I access the Aux/Game channel on the BH2404D if my remote will not work.
  • 48 Answers
Unless you can channel down to below 0, you might be lucky, otherwise there is no way to do it
Posted on Apr 23, 2009
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
Not able to get the auxillary channel. I know to channel down but it does from 1 to 125. I've tried the preset channels again - it doesn't show. Game is on. I have the remote. Any suggestions?
It's possible that the AUX channel was erased from the display menu. Go to your CHANNEL SET menu choice and and use your DOWN CHANNEL button to see if the AUX channel will come back.
Mar 06, 2010 | Sylvania SST4322 32" TV
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
How do i get to the aux channel on a Sansui TVM131AD
if your tv doesn't have an AV button either buy a all in 1 remote or a RF cable compatable with your game console and tune the tv manually as you would tune tv stations
May 15, 2009 | Televison & Video
Durabrand DWT2405 Aux/Game Channel
i need remote code for durabrand tv dwt 2405
Mar 03, 2009 | Durabrand DWT2405 24" TV
Is There a way to go to video/input without a remote.
My answer will be generic.
With many of these TV sets the original factory remote is required to change the input mode of the set, or to access any of the user menus.
On some models of sets, putting the channel selection down to below channel 2, puts the TV in to the external input modes.
Jerry G.
Feb 10, 2009 | Emerson Televison & Video
Cannot access the aux/ line1 or line 2 channels
I have this TV too... the Aux channel is right before channel 1. Just use the keys on your tv itself and go to the channel before 1. (:
Jul 11, 2008 | Broksonic CTGV-5463TCT TV
Programming AUX as a channel.
pick up a universal remote
Mar 28, 2008 | Televison & Video
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
298 people viewed this question
Top Televison & Video Experts
Electro Med Services...
