Question about Vacuums
I was told that the brush assembly(black plastic holders)should be inverted/fliped over when doing maintenance on my orickXL vacuume cleaner? So not to wear out the brush assembly is this correct?
  • 116 Answers
You adjust it to adapt to the wear of your brush. they will make your brush higher or lower since the hole is offset. if you were to install a new brush you would want it as far away from the carpet as possible and vise versa.
Posted on Apr 23, 2009
How do I replace a broken belt on vacuum cleaner - Hoover Modell U5465-900?
The Brush is pressed into a small holder on each side of the vacuum case. You must pull the brush forward (out) from the holders and on the brushes side is a spindle where the rubber belt wraps around. Remove the old belt, clean off all debris and put the one end of the new belt on the spindle end of the vacuum motor and the other on the brush end. Push brush roller back in place and you are good to go.
Feb 08, 2018 | Hoover Vacuums
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
I cant get the brushes to spin on my hoover max extract carpet cleaner
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Jan 28, 2011 | Hoover Vacuums
How to replace central vacuums Carbon Brushes
The entire brush and holder assembly has to be purchased/replaced. That's the plastic piece that screws on to the motor. I don't think you can even get brushes for their machines anymore.
Remove screws. Remove plastic piece from motor. Replace.
Oct 17, 2010 | Electrolux Central Vacuum
My bissell helix cleanview vacuums brush doesn't spin
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
The brushes on my Hoover steam spin carpet cleaner will not spin.
Hello, their is two reason why the brushes don't spin, one would be the brush brock is broken, take out the brush, and mnake sure their is a plastic two inch shaft sticking out, if not, then the brush block needs to be replaced, if fine, the the turbine is frozen and will need to be replaced, take the lid off and replace the black turbine, I can send you anything you need, or if you have any questions feel free to call 1561-848-3387 Thank you, Teresa.
Clean sweep Vacuums
Aug 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
I bought a replacement brushroll because the one in the vaccum cleaner is worn out.How do I go about putting the brush in the vaccum cleaner. Do I pull it out or do I have to unscrew the entire bottom...
Greetings from GoVacuum,
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is chris.jones@govacuum.com.
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out http://www.govacuum.com for all Oreck vacuum cleaner parts and supplies!
Chris Jones
GoVacuum.com
Mar 16, 2010 | Oreck XL2000 Bagged Upright Vacuum
I have a hoover carpet cleaner with the 6 brushes and they have stopped turning i have cleaned the little screen and still no results what may be the problem
i found a copy of the manual on the inter net and was looking through it and it told me how to takemy brush assembly out, so i did that and replaced my brush assembly. it was really easy and only cost 25.00. thanks for the help
Marilyn Lambertson
Jun 20, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Jan 29, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
